My exhaust(s) have been catching quite some rust lately. I live in an area with much rain and cold, moist winters, which probably accelerates the deteriation.
- What's the best way to remove the rust?
Pressured air driven metal-brush?
Seems good for the stock-exhaust, but on the LeoVince I need something that won't mess up the cool finish on it.
- How do I protect the metal from rusting when I've removed the old rust? Can anybody recommend some kickass paint that truly works? Most paints can't handle the heat.
1. A matte black color that matches the original exhaust. A shining deep black color would look pretty silly.
2. A clear coat for my LeoVince ZX exhaust.
Thanks a lot.
Rusting exhaust - how to cure and prevent?
- Tricycle Squid
- Real Name: Luigi
- Years Riding: 3
- My Motorcycle: 2012 HD XL1200C
- Site Supporter - Silver
- Real Name: Pete
- Years Riding: 10
Re: Rusting exhaust - how to cure and prevent?
rustoleum Hi-Heat paint, at any auto parts store,
is made for headers and exhaust.
Read the manufacturer's data sheet.
- Veteran
- Real Name: Johnny
- Years Riding: 3
- My Motorcycle: Honda
Use SOS pad or steel wool to remove the rust. Then clean it thoroughly. Depending on your budget, you can have it powder coated or just use a high-temp paint.
- Tricycle Squid
- Real Name: Steve
- My Motorcycle: honda 70 2015
To remove rust from your exhaust, you can use a pressured air-driven metal brush. However, you may need a gentler method for an exhaust to preserve its finish. As for protecting the metal from future rusting, you can use a rust converter like Metal Rescue Rust Remover and then apply a heat-resistant paint like a matte black color that matches the original exhaust or a clear coat.
