2016 Aprilia RSV4 R-FW - Coolness Factor = 82.6%
Your Coolness Factor of the 2016 Aprilia RSV4 R-FW is:
View results
Years Riding: 32
2016 Aprilia RSV4 R-FW on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... actory.htm
Create and Be a Legend...
THE APRILIA RACING TEAM USES ITS EXPERIENCE IN THE TOP WORLD COMPETITIONS TO CREATE THE NEW "FACTORY WORKS" VERSIONS OF THE AWARD WINNING APRILIA RSV4
AN EXTRAORDINARY RANGE OF "SPECIAL" HIGH PERFORMANCE BIKES PRODUCED AND SOLD DIRECTLY BY APRILIA RACING: THE RACING DIVISION WITH 54 WORLD TITLES WILL ALSO PROVIDE FIRST-HAND ASSISTANCE
The Aprilia RSV4 has the ultimate racing history for a single production-derived model.
This extraordinary 1000cc Italian V4 has won 7 titles in the Superbike World Championship from 2009 to today, besides winning the Rider and Manufacturers titles for the FIM Cup Superstock 1000, in 2015.
An exceptional racing career which stems from technical leadership, the model has consistently proved its worth as it keeps winning comparative trials organised by the world's top bike magazines.
Aprilia Racing, the Racing Division that has earned the Noale-based manufacturer 54 World Titles, introduced a program today to make the same technology that was developed for the championship winning bike available to anyone who wishes to compete in factory derivative championships or who wants an RSV4 with racetrack optimised performance.
Romano Albesiano, Aprilia Racing Director comments on this extraordinary project by the racing division in Noale: "The RSV4 racing versions we are presenting at EICMA are, first and foremost, a unique opportunity that Aprilia Racing is making available to those who want to own a real race bike. At the Aprilia Racing Division we worked to pack all the know-how behind the RSV4 into these exceptional bikes: know-how which has made the RSV4 one of the top winning bikes in the history of production-derived bikes. The SSTK Championship victory this year is an addition to 7 world titles we've won in the SBK. Now all the experience we have acquired through these victories is available to whoever wants to race with our bike: both those who want to participate in championships and those who want to ride a real Aprilia Racing bike on the racetrack. We're making several levels of sophistication available. This is a racetrack optimised RSV4, from the SSTK version (in every way the bike that dominated the Superstock 1000 FIM Cup) all the way to the top, a full-fledged Superbike".
The program will create "Factory Works" bikes compliant with Superstock and Superbike Championship regulations in each country, with various levels of preparation in the engine and electric components and with a maximum configuration that exceeds 230 hp.
All versions start with the already exceptional technical base of the Aprilia RSV4 RR.
2016 Aprilia RSV4 R-FW http://www.Totalmotorcycle.com Key Features
Aprilia Racing RSV4 R-Factory Works - Race Winning Aprilia Technology Now Available To All
RSV4-R Factory Works
Aprilia Racing, the Racing Division that has brought the Noale-based Manufacturer 54 world titles, introduces at EICMA 2015 the "Factory Works" program which makes the same technology developed for the world champion bike available to anyone who wants to compete in factory derivative championships or who simply wants to have an RSV4 with optimized performance for track use.
The Aprilia Racing “Factory Works” bikes will be developed and made available to customers in accordance with the regulations of the Superstock and Superbike championships in the various countries, with different chassis preparation, electronic and engine levels which, at the top configuration (picture), exceeds the threshold of 230 HP. All of the versions begin with the already exceptional technical base of the Aprilia RSV4 RR. In usual Aprilia Racing tradition, each component has been optimized for maximum performance whilst maintaining a high overall balance and a high level of reliability. This is why every Aprilia “Factory Works” bike is one that will cut a fine figure at any level of competition, but it is also an “attainable” dream for enthusiasts looking for an extraordinary track vehicle with the certainty that nothing can bring you closer to the sensations that a World Superbike champion feels.
2016 Aprilia 2016 Aprilia RSV4 R-FW - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $16499 USD
ENGINE
Type Aprilia V4 longitudinal 65°, 4-strokes, liquid cooling system, double overhead camshaft (DOHC), four valves per cylinder
Capacity 999.6 cc
Max power (at crankshaft) 201 hp (148 kW) at 13.000 rpm
Max torque (at crankshaft) 86 lb-ft (115 Nm) at 10.500 rpm
Fuel system Airbox with front dynamic air intakes. Variable length intake ducts controlled via ECU. 4 Weber-Marelli Ø48-mm throttle bodies with 8 injectors and latest generation Ride-by-Wire engine management. Choice of three different engine maps selectable by the rider with bike in motion: Sport - Track - Race
Exhaust system 4 into 2 into 1 layout, single oxygen sensor, lateral single silencer with engine control unit-controlled butterfly valve and integrated trivalent catalytic converter.
TRANSMISSION
Gearbox 6-speed cassette type gearbox
Lubrication Wet sump lubrication system with oil radiator and two oil pumps (lubrication and cooling)
Clutch Multiplate wet clutch with mechanical slipper system. Gear lever with Aprilia Quick Shift electronic system 'AQS'
Traction management APRC System 'Aprilia Performance Ride Control', which includes Traction Control (ATC), Wheelie Control (AWC), Launch Control (ALC), all of which can be configured and deactivated independently through the race display.
CHASSIS / SUSPENSION / BRAKES
Frame Aluminium dual beam chassis with pressed and cast sheet elements.
Front suspension SACHS steering damper.
Ø43mm SACHS upside down units fully adjustable. Wheel travel: 120 mm
Rear suspension Aluminum alloy swingarm. SACHS piggyback shock absorber with adjustable spring preload, compression, rebound damping and length. Wheel travel: 130 mm
Front brake Double Ø320mm lightweight stainless steel floating discs. New M430 Brembo monobloc radial calipers with 4 opposed Ø30 mm pistons. Sintered pads. New radial master cylinder. Metal braided brake line.
Rear brake Ø220 mm disc. New Brembo floating caliper with 2 insulated Ø 32 mm pistons. Sintered pads. Master cylinder with integral reservoir. Metal braided brake line
ABS Multi-map Bosch 9MP ABS (3 maps selectable + off ), deactivable and with RLM (Rear wheel Lift-up Mitigation).
Wheels Aprilia Aluminum alloy rims, 3 split spokes. Front:3.5”X17” Rear: 6.00”X17”
Front tire Radial tubeless - 120/70 ZR 17
Rear tire Radial tubeless - 200/55 ZR 17 (homologated option 190/50 ZR 17; 190/55 ZR 17)
DIMENSIONS
Max. Length 80.3 in. (2040 mm)
Max. Width 29 in. (735 mm) at the handlebar
Max. Height 44 in. (1120 mm)
Seat height 33 in. (840 mm)
Dry weight 398 lbs (181 kg)
Fuel tank capacity 4.9 gal. (18,5 lt)
WARRANTY / ROADSIDE ASSISTANCE / APPROVAL
Warranty All 2015 and newer Aprilia Motorcycles include a 2-year unlimited-mileage warranty. *Limits are outlined in the warranty booklet. See dealer for details
Roadside Assistance 1 Free Year of Road Side Assistance provided by Road America.
Approval EPA and CARB
2016 Aprilia RSV4 RR (Specs) - http://www.Totalmotorcycle.com Canadian Specifications/Technical Details
Canada MSRP Price: $16995 CDN
ENGINE
Capacity 999.6 cc
TRANSMISSION
ABS Multi-map Bosch 9MP ABS (3 maps selectable), deactivable and with RLM (Rear wheel Lift-up Mitigation).
DIMENSIONS
2023 Motorcycle Model Guides
Years Riding: 32
Re: This Week: 2016 Aprilia RSV4 R-FW
Ok, this model can be VERY confusing. It is the first time (modern) that a manufacturer has offered up so many choices in one model with the key of going from superbike to hyperbike to full on Superbike world championship (SBK) race bike.
Quite an amazing feat.
So the variants are the following all based on the Aprilia RSV4 R-FW:
RSV4 R-FW Stock1 MM Race
- An Aprilia RSV4 with Race Pack (Öhlins suspension and forged rims).
- Standard electronic system with an extra light lithium battery.
- ECU reprogrammed to Race version with race maps for engine and bike management, developed by Aprilia Racing.
- Settings reprogrammed for race use.
- Braking optimised and weight reduced, ABS removed
- Engine weight reduced without the water thermostat, with a simplified water tubes kit and secondary air system closed.
- Optional: Akrapovic exhaust kit, complete fairing kit, dedicated suspensions setting and complete engine optimisation.
RSV4 R-FW Stock2 APX Race
- Simplified, lightweight, racing version electronic system with dedicated bike and engine wiring and a lithium battery.
- APX2 logic unit developed by Aprilia Racing: ignition and engine control parameters may be programmed with the included hand terminal.
- Data acquisition system allows logging of original sensors as well as optional sensors allowed by FIM Superstock 1000 rules.
- Special Aprilia Racing instruments.
- Special engine with Aprilia Racing preparation.
- Optional: Akrapovic exhaust kit, complete fairing kit, dedicated suspensions setting.
RSV4 R-FW SBK
- APX2 logic unit developed by Aprilia Racing, complete with GPS module, ignition and engine control parameters may be programmed with the included hand terminal. The unit includes a data acquisition system with optional telemetry sensors kit.
- Special Aprilia Racing instruments with racing buttons.
- Electronic gearbox with assisted shifting (blipper).
- Special Aprilia Racing tools.
- Special engine with SBK preparation by Aprilia Racing.
RSV4 R-FW W-SBK
- Replica of the RSV4 Superbike used by the official Aprilia Racing Team in the SBK Wold Championship.
- Both the bike and the level of assistance may be tailor made in accordance with the budget and ambitions of each rider and team.
It is the best that can be desired and allows one to have a star role in the Superbike world championship.
RSV4 R-FW "MISANO"
- The bike presented at EICMA is a demonstration of the level of preparation possible through the "Factory Works" program and is the entry level for the W-SBK line.
- In true Aprilia Racing style each component has been optimised to offer the best in performance while maintaining elevated overall balance and reliability.
- It is a bike that can do well at any competitive level, while remaining "within reach" of enthusiasts who desire an extraordinary bike to exercise their racing skills, knowing that nothing can come closer to the rush felt by SBK World Championship champions.
- The colour scheme is a celebration of Aprilia's first victory in a "road racing" competition and underscores the exclusivity of the model
I hope that clears the air some. :)
ceemes
Real Name: a big secret
#3 Unread post by ceemes »
Full On Racing Bike equals awesome.....would I ever ride one? hell no.......I wouldn't want to get within 10 feet of one for fear it would jump up and bite me.
ZRex
Real Name: Ben
#4 Unread post by ZRex »
Awesome, I can't think of anything else to say, except this bike is Awesome.
Grey Thumper
Real Name: Dino
#5 Unread post by Grey Thumper »
It's a fast Italian superbike, so it at least deserves a solid cool. It feels like a bit of a last hurrah for a fairly old design though. This is basically the ultimate version of a bike that was first launched in the previous decade.
Years Riding: 32
Voted Awesome as well.
Amazing that Aprilia has offered up four fully customized versions of their hot superbike. What a great idea!
230hp? Wow, that's amazing power as well. I wonder if we will see 300hp bikes in 10-20 years from now becoming the norm?
Years Riding: 32
Featured: February 11th - February 18th 2016
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=52757
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... actory.htm
Awesome (3 points) 52% [ 12 ]
Cool (2 points) 43% [ 10 ]
Uncool (1 point) 4% [ 1 ]
Fail (0 point) 0% [ 0 ]
Total votes: 23
= a Coolwall Factor of 82.6%
Notes: Everyone agrees, it's an awesome bike with an awesome concept. Top of the charts in performance. We will have to see how Aprilia tops this in the future with the next RSV model. Any guesses? Maybe an RSV6? :revv:
[/i]Get excited as the next TMW Cool Wall bike for 2016 is now up for voting and discussion, have fun!
