2015 Hyosung GD250N - Coolness Factor = 41.7%
Your Coolness Factor of the 2015 Hyosung GD250N is:
View results
Years Riding: 32
2015 Hyosung GD250N on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... GD250N.htm
Your way to experience the ease of excitement...
The 2015 Hyosung GD250N / X4 EFI / X4 is all new ground for Hyosung with 98% new parts on this exciting new 250 single street bike. A fresh design with a high torque, liquid cooled, fuel injected, DOHC, 4 valve single cylinder engine which sets a new bench mark for this class of engine. Power and torque figures are impressive with 28.4 hp @ 8500 rpm and 26.1 Nm @ 7000rpm channelled through a 6 speed gearbox.. Yes more than enough to cross any intersection ahead of most other commuters. The new chassis starts with USD KYB forks, steel trellis perimeter frame, bolt on steel sub frame, aluminium swingarm, KYB rear shock and lightweight wheels. Keeping the centre of gravity low is a under slung stainless muffler. To stop this commuter wild thing you have a 4 piston front caliper gripping a lightweight disc and a dual opposed piston rear caliper with braided stainless brake lines. The rider is kept informed by a digital dash with gear position indicator and vibes are low thanks to the tapered handlebars. Dry weight is only 135kg making for a top of the class power to weight ratio.
2015 Hyosung GD250N / X4 EFI http://www.Totalmotorcycle.com Key Features
The X4 is all new ground for Hyosung with 98% new parts on this exciting new 250 single street bike. A fresh design with a high torque, liquid cooled, fuel injected, DOHC, 4 valve engine which sets a new bench mark for this class of engine. Power and torque figures are impressive with 28.4 hp @ 8500 rpm and 26.1 Nm @ 7000rpm channelled through a 6 speed gearbox.. Yes more than enough to cross any intersection ahead of most other commuters. The new chassis starts with USD KYB forks, steel trellis perimeter frame, bolt on steel sub frame, aluminium swingarm, KYB rear shock and lightweight wheels. Keeping the centre of gravity low is a under slung stainless muffler. To stop this commuter wild thing you have a 4 piston front caliper gripping a lightweight disc and a dual opposed piston rear caliper with braided stainless brake lines. The rider is kept informed by a digital dash with gear position indicator and vibes are low thanks to the tapered handlebars. Dry weight is only 135kg making for a top of the class power to weight ratio.
The overall package is very promising indeed and the X4 will set a new standard of nimble, lightweight commuter bike.
Colours:
Black
Red
White
Blue
Colour choice subject to availabilty
Two year / 20,000km factory warranty.
201n Hyosung GD250N / X4 EFI - http://www.Totalmotorcycle.com International Specifications/Technical Details
US MSRP Price: $3799 USD
Canada MSRP Price: $ See Dealer CDN
Australia/NZ MSRP Price: $ See Dealer
ENGINE
Type Liquid cooled DOHC 4-valve Single cylinder
Displacement 249cc
Bore x Stroke 73 x 59.6
Compression Ratio 12 : 1
Max Power 21.2 kW (28.4 HP) @ 8500 RPM
Max Torque 26.1 Nm (2.56 kgf.m) @ 7000 RPM
Fuel System Fuel injection
Lubrication Wet sump
TRANSMISSION
Clutch Wet, Multiplate
Gear Constant mesh, Close ratio 6-speed (1down 5up)
Final Drive Chain
CHASSIS
Frame Type Steel tubular trellis perimeter main frame & Steel tubular assembly sub frame
Overall Length 1937mm
Overall Height 1100mm
Overall Width 700mm
Wheel Base 1346mm
Ground Clearance 135mm
Seat Height 810mm
Caster 23.5 °
Trail 93.6mm
Brake F: 300Ø Petal shaped spoke mounted single disc, 4 opposed pistons caliper, Stainless mesh hose
R: 230Ø Petal shaped single disc, 2 opposed pistons caliper, Stainless mesh hose
Suspension F: 37Ø Upside down Telescopic
R: Dual side Aluminum Swing arm with Gas charged Hydraulic shock absorber (Nonstep Preload adjustable)
Tyre F: 110/70 R17 54S / R: 150/60 R17 66S
Fuel Tank Capacity 11L
Curb Weight 155kg
2023 Motorcycle Model Guides
Years Riding: 32
Re: This Week: 2015 Hyosung GT250N - Vote Now
New from Hyosung, the GT250N (and GT250 in Canada). A stylish budget buster bike designed not to break the bank or your back!
Badass bike or Bust?
faded sun
Years Riding: 46
Re: This Week: 2015 Hyosung GD250N - Vote Now
#3 Unread post by faded sun »
At $5k Canadian dollars ( based on current exchange for that USD price tag), it's a bit dear for my tastes for a 250. It would help if they could decide whether it is a single cylinder or a v-twin ( does anybody read these promo pieces before they get published?). It looks ok if you want the naked look. Anybody ridden one?
Jock
ceemes
Real Name: a big secret
#4 Unread post by ceemes »
A naked learner bike, a bit pricey tho......mine you in some parts of the world, namely South East Asia, it would be considered a fair sized bike.
Grey Thumper
Real Name: Dino
#5 Unread post by Grey Thumper »
It's . . . okay. I dunno if I'd pay that much for a Hyosung, to be honest. For that kind of money, I'd get a used Honda CRF250, Honda CBR250R, Suzuki GW250, or a Kawawsaki Ninja 250. If the buyer was into cruisers, I'd recco the good old Honda Rebel.
Years Riding: 32
I voted: Cool
Hyosung is trying, and I'll give them kudo's for that. But it's hard to get excited about a bike that in price is so close to the major competitors versions. It's a Honda car issue in the 70's and a KIA/Hyundai car issue in the 90s. One day, like Honda auto has done, Hyosung will be able to change around the same prices but that's not today so Hyosung really needs to keep competitive. Unfortunately, our Canada dollar hit a 11year low on Wednesday vs the USD. This is GREAT for our exports but horrible for imports as it raises prices for all Canadians. A $5k 250cc might look like a steal next year!
The GD250N (and GD250F) is a good step forward to bring a modern design, look and feel to a budget bike. Hyosung has come light years ahead of the Chinese products in terms of quality and R&D. The engine is competitive in power, the bike is very competitive in weight. It looks good and is unique. All Hyosung needs to do is expand their dealer network and work a little on the price.
BTW, price is Canada "is around $4k" if that helps. Unfortunately, I couldn't find a price on Hyosung's Canada site nor elsewhere, but I will call Hyosung about it.
Years Riding: 32
Featured: September 18th, 2015 - September 25th 2015
Most popular vote category: Uncool
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=52070
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... GD250N.htm
Awesome (3 points) 5% [ 1 ]
Cool (2 points) 30% [ 6 ]
Uncool (1 point) 50% [ 10 ]
Fail (0 point) 15% [ 3 ]
Total votes: 20
= a Coolwall Factor of 41.7%
Notes: Sadly, some motorcycle model has to come dead last on the Cool Wall, and currently, that's the new 2016 Hyosung GD250N. And why is that? What makes a new model fail so badly in the eyes of riders everywhere? Surprisingly, it's not horsepower or weight. But the price. There are just too many good new and used bikes out there for around the same cost. Riders are willing to pick a new/used Honda CRF250, Honda CBR250R, Suzuki GW250, or a Kawawsaki Ninja 250 and that's an issue for the new GD250N.
Years Riding: 32
faded sun wrote:At $5k Canadian dollars ( based on current exchange for that USD price tag), it's a bit dear for my tastes for a 250. It would help if they could decide whether it is a single cylinder or a v-twin ( does anybody read these promo pieces before they get published?). It looks ok if you want the naked look. Anybody ridden one?
Sorry, that was my fault there, I initially mixed up the GT250 and GD250 description.
