Mintbread wrote:Are you sure it is not for the rebound settings?
positive, kawasaki cheaped out on the rear shock. Hell, for the front forks they through in some springs set for a 400 lb rider and said ""fudge" it". It's also been said by some members on the 650 boards that it's one of, if not the easiest bike to turn the adjuster on they've ever used.
If you want rebound and damnpening, you need a penskie shock, which are $$$ like woah ($700 i think for 2-way)
NorthernPete wrote:and if it doesnt work..get a bigger hammer!
Verm, living in CA, wont removing the catalitic converter do something for the emissions thing? (just curious, I really have no idea. enlighten me)
x2. CA is pretty strict on emissions. Do some research first. Didn't CA pass a decible inspection law as well?
2002 Buell Blast 500 /¦\
Mintbread wrote:
YOU HAVE TO HAMMER IT!
Be it with the "special tool" or not. You need a hammer to undo the locking ring.
Secondly the rear preload does not have "settings". It doesn't click into place or show a number it is as simple as UP IS SOFTER AND DOWN IS HARDER.
Damn, you be ignorant...
nope, if you have the right tool. you won't need to hit it w/ a hammer. or maybe you still do but it sure as hell won't require forcing it with a screw driver.
regarding the pipe... all AM pipes is not street legal here. everyone does it and as long as you're not doing anything very dumb, cops don't usually care.
I think most cops have better things to do than worry about some bike's pipes, unless he's having a bad day. What I think everyone was asking is the inspection part. Unless you are going to swap your stock exhaust back onto the vehicle for inspection, how will it pass?
