3-30-07 Friday, 65 F, superb weather.
Today was the first real day I tried installing my speedo.
I started at about 12:30 PM until about 8:00 PM with some breaks and stops to ACE hardware in between.
Alright so if you would, I have some questions in between so read it.
My main questions deal with how to integrate my speedo into the ignition system and how to install the speedo.
Start:
Took off the dash (It took me 1 hour alone to take off the dash, all the bolts were stripped and I had to hand crank it out) and installed my speedo...
Alright, so heres my first question: How do I integrate my "ignition" wire from my speedo to the ignition system of my bike securely? Here are pictures of what comes out from the igntion.
T
The red wire is the wire I need to somehow install onto the ignition system.
Second question, Does anybody have any idea on how to install the two magnetic bolts and the "sensor" on to my front wheel???
Third Question, does anybody know what what I need to install my RPM sensor to? I dont know what the "CDI" or "HT Coil" is I think I found what looks like the same thing on my instructions and is this it? And if so, do I strip it, wrap my wire around it, then close it with elec. tape?
Heres the instructions
And here is what I think the RPM thing should be wrapped around.
Alright. By the time I went to ace hardware 10 times, ate lunch, ate dinner and did all this crap it was 8 PM and dark as heck so I had to call it quits. I can't work on it until next Wednesday so I was hoping if I could get some helpful advice on my questions. The only reason I didn't try it myself was because it was getting too dark and I was WAY too tired.
Good bye bike.
