Turn signals.
- NorthernPete
- Real Name: Pete
- Years Riding: 11
Turn signals.
Replacing my turn signals (front and rear) they appear the same. My new ones are two wires. The front ones have two while the rears on the bike atm only have one. Thought maybe they were grounded internally. I hooked up the hot and tested it figuring I'd need to ground it. But the light works without the ground being hooked to anything. Why is this?
2009 GS500F
2009 GS500F
- Johnj
- Real Name: Johnny Strabler
Re: Turn signals.
The frame is ground. Power comes in on the wire and leaves on the frame.
- NorthernPete
- Real Name: Pete
- Years Riding: 11
Re: Turn signals.
Hmmmm. I wonder what the other wire is on my signal then. It's green if that helps.
2009 GS500F
2009 GS500F
- Gummiente
- Years Riding: 38
Re: Turn signals.
How many contacts are on the base of the bulb? If there's only one then the green wire is likely just a ground for Euro spec bikes, as their practice is to use ground wires rather than frame ground. If there's two contacts, then they are meant to be used as running lights/signal lights on the front.
It isn't WHAT you ride,
It's THAT you ride
It's THAT you ride
- NorthernPete
- Real Name: Pete
- Years Riding: 11
Re: Turn signals.
Got it all figured out. Ground wires in the back were grounded to the bolt stalk. Front was wired into the bucket. All done now.
2009 GS500F
2009 GS500F
