White stuff on chain - Problem?
roncg41677
#1 Unread post by roncg41677 »
I've got a lot of white junk on the inside of my chain. I've noticed that the spray lube I have (came with the bike, no idea how old it is) leaves a white residue when I spray it, so I think it's just that stuff. Is it supposed to be that color? Is it normal for it to dry on there and make the chain look like I rode through a white-out spill?
[i]Matthew 6:33 - But seek first His kingdom and His righteousness, and all these things will be given to you as well.[/i]
'93 Yamaha Seca II
'92 Yamaha Seca II (Fixing up)
#2 Unread post by Johnj »
Yes that's normal.
roncg41677
#3 Unread post by roncg41677 »
Okay. I thought maybe the chain was supposed to stay shiny and black. Thanks :).
'93 Yamaha Seca II
flw
#4 Unread post by flw »
Do you mean white foam as your applying the oil spray or long after you have even riden the bike?
If you take the substance and rube it between your fingers. Does it feel like thick grease or grit or something else?
A spray propellant can give oil a temporary white appearance but that should go away quickly.
Goldwing 1500se '98
VN500 LTD '07 Sold
roncg41677
#5 Unread post by roncg41677 »
Well, the bike's been sitting for about a month not running. But it's always on there, even weeks after I've sprayed on the lube.
'93 Yamaha Seca II
Gadjet
Real Name: Owen Clark
Years Riding: 19
#6 Unread post by Gadjet »
it's chain wax.
I used to use the same stuff on my chain, but while it lasted a long time, it also collected road gunk really well (I used PJ-1). I now lube my chain with a multipurpose spray on lube that works really well.
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
brandon12
Real Name: brandon dep
My Motorcycle: FLH ELECTRA GLIDE
Re: White stuff on chain - Problem?
#7 Unread post by brandon12 »
Hi, don't worry that's normal I had same issue of that white stuff on chain with my previous bike.
Miles_Ha11
Real Name: Miles Hall
Years Riding: 3
My Motorcycle: 2016 Ducati Supersport
#8 Unread post by Miles_Ha11 »
I am sure that he had managed to clean it up since its been years when this query was created.
