Total Motorcycle Forums • View topic - 2013 BMW F700GS: Voted - Cool
Your Coolness Factor of the 2013 BMW F700GS is...
Awesome
Cool
Uncool
Fail
View results
Unread postPosted: Fri Jul 06, 2012 9:45 am
Years Riding: 20
2013 BMW F700GS: Cool Wall Vote & Discuss
More photos and information: http://www.totalmotorcycle.com/motorcycles/2013models/2013-BMW-F700GS.htm
2013 BMW F700GS
Carefree motorcycling fun for everyone!
Off-road or urban – new, authentic character with improved functionality in typical GS style. With the F 700 GS – the direct successor to the F 650 GS. A shorter gear transmission ratio in the 75 bhp engine enhances agility while at the same time guaranteeing the bike's familiar top-class handling. This makes the F 700 GS an ideal all-round machine within the GS family, suitable for every kind of rider – no matter how experienced.
What was good has just got better: with ABS as standard and ESA (Electronic Suspension Adjustment), not to mention ASC (traction control) as an option, the ride is not just safer but also offers especially high comfort. Low weight, reduced seat height and a lowering option make the F 700 GS a perfect all-round enduro bike.
GS feeling everywhere: the new design of the windshield and dial faces and the smoke-tinted turn indicators and LED rear light give the F 700 GS the grown-up look it deserves. The three colour variants offer something for everyone: muted Red Apple Metallic, masculine Ostra Grey metallic matt and dynamic Glacier Silver metallic.
As usual, there is once again a wide range of options and special accessories for the F 700 GS to allow you to tailor your BMW to your individual preferences.
That's the new F 700 GS. The ultimate all-rounder.
2013 BMW F700GS Features and Benefits
When BMW Motorrad extended the GS family with an entry-level and medium category in 2007 in the form of the F 650 GS and the F 800 GS, there was no doubt as to the message: lots of riding fun based on light, safe controllability over all surfaces, plenty of drive power and endurance on trips - even when there are only gravel tracks left to get you where you're going. A concept in two versions which many motorcycling fans responded to enthusiastically.
2013 BMW F700GS Key Features
- Increased output and torque in the F 700 GS as compared to predecessor model:
55 kW (75 hp) at 7,300 rpm (F 650 GS: 52 kW [71 hp] at 7,000 rpm).
- The latest generation of BMW Motorrad two-channel ABS as standard.Double disc brake system at front - now also for F 700 GS.
- Automatic Stability Control ASC (ex works option).
- Electronic Suspension Adjustment ESA (ex works option).
- Rear spring mount can be adjusted via optimised handwheel.
- Newly designed body features in a more dynamic, masculine look.
- New paint finishes for the F 700 GS:
- New handlebar switch units and brake fluid containers, front.
- New handlebar clamp for F 700 GS.
- Cockpit with new dial faces for speedometer and engine speed display and an extended range of information.
- New windshield for F 700 GS.
- Smoke grey turn indicators and smoke grey LED rear light glass covering.
- Power reduction to 35 kW (48 hp) (ex works option).
- Engine map adjustment for regular fuel (RON 91) (ex works option).
- Comfort seat now available as an ex works option too.
- Case carrier for Vario case now also available as an ex works option.
- New centre stand as ex works option.
- Comfort package: on-board computer, heated grips, case holder, centre stand (ex works option).
- Safety package for F 700 GS: ASC, ESA, RDC (ex works option).
- Enduro footrests, wide (special accessory).
2013 BMW F700GS - USA Specifications/Technical Details
Engine
Type Water-cooled 4-stroke in-line two-cylinder engine, two overhead camshafts, four valves per cylinder, dry sump lubrication
Bore x stroke 82 mm x 75.6 mm
Capacity 798 cc
Rated output 55 kW (75 hp) at 7,300 rpm
Max. torque 57 lb/ft (77Nm) at 5,300 rpm
Compression ratio 12.0 : 1
Mixture control / engine management Electroinc intake pipe injection, digital engine management (BMS-K+)
Emission control Closed-loop 3-way catalytic converter, emission standard EU-3
Performance / fuel consumption
Maximum speed 119 mph
Fuel consumption per 100 km at constant 90 km/h 60 mpg, at a constant 55 mph
Fuel consumption per 100 km at constant 120 km/h
Fuel type Premium unleaded
Electrical system
Alternator three-phase alternator 400 W
Battery 12 V / 12 Ah, maintenance-free
Power transmission
Clutch Multiple-disc clutch in oil bath, mechanically operated
Gearbox Constant mesh 6-speed gearbox integrated into crankcase
Drive Endless O-ring chain with shock damping in rear wheel hub
Chassis / brakes
Frame Tubular steel space frame
Front wheel location / suspension Telescopic fork, Ø 41 mm
Rear wheel location / suspension Cast aluminium dual swing arm, central spring strut, spring pre-load hydraulically adjustable (continuously variable) at handwheel, rebound damping adjustable
Suspension travel front / rear 7.1/6.7 inches (180mm/170 mm)
Wheelbase 61.5 inches (1,562 mm)
Castor 3.7 inches (95 mm)
Steering head angle 64°
Wheels Cast aluminium wheels
Rim, front 2.50-19
Rim, rear 3.50-17
Tyres, front 110/80-19 59H
Tyres, rear 140/80-17 69H
Brake, front Dual disc brake, diameter 300 mm, double-piston floating caliper, ABS
Brake, rear Single disc brake, diameter 265 mm, single-piston floating caliper, ABS
ABS Standard
Dimensions / weights
Length 89.8 inches (2,280 mm)
Width (incl. mirrors) 35.0 inches (890 mm)
Height (excl. mirrors) 48.8 inches (1,240 mm) (Serial windshield)
Seat height, unladen weight 32.3 inches (820 mm) (low seat: 31.1 inches [790 mm], lowered suspension: 30.1 inches [765 mm], comfort seat: 32.9 inches [835 mm])
Inner leg curve, unladen weight
Unladen weight, road ready, fully fuelled 1) 461 lbs (209 kg)
Dry weight 2) 410 lbs (186 kg)
Permitted total weight 961 lbs (436 kg); with lowered suspension 796 lbs (349 kg)
Payload (with standard equipment) 500 lbs (227 kg); with lowered suspension 309 lbs (140 kg)
Usable tank volume 4.2 gallons (16 liters)
Reserve Approx. 1 gallon (4.0 liters)
2013 Motorcycle Model Guides
2012 Motorcycle Model Guides
2013 ATV/Quad Model Guides
Unread postPosted: Fri Jul 06, 2012 5:37 pm
Why is an "800cc" engine called a 700? :?
Unread postPosted: Fri Jul 06, 2012 6:08 pm
Years Riding: 20
Ya, I know. BMW started doing that for the 2012 motorcycle model year, now they have 3 bikes (that I can recall off the top of my head) that are named "inaccurately".
The F700GS = 798cc engine, 75hp (maybe should have been called the F750GS or F800GS).. while the F800GS has a 798cc engine with 85hp (not sure if they are the same engine, I haven't looked into that yet).
The F650GS = 798cc engine with 71 hp (renamed to F700GS above)
The C600 Sport = 647cc engine (while the C650GT uses the same engine)
I guess you could see it as a "bonus" for your insurance cost. :D
Unread postPosted: Fri Jul 06, 2012 7:45 pm
totalmotorcycle wrote:
Ya, I know. BMW started doing that for the 2012 motorcycle model year.....
BMW started doing that for the 2009 model year, we have a 2009 F650GS that is an 800 twin. I liked it better when the name and the engine size of their bikes matched.
I'll give it a Cool anyway, I like all the BMW 800 twins (even the ones that are named wrong...)
2005 Triumph Bonneville
2005 Suzuki V-Strom 1000
Unread postPosted: Fri Jul 06, 2012 8:56 pm
Years Riding: 20
That's right 2009...lol Oh well, back to my beer. :cheers:
Unread postPosted: Sat Jul 07, 2012 11:10 am
Years Riding: 2
My Motorcycle: 2006 Yamaha MT-01
I really like the look of these bikes, but what is up with the small fuel tanks? 16L? Every street bike should have a minimum 20L tank, and if it is over 1000cc 25L. I want to be able to go between 300-400kms before HAVING TO refuel. I don't want to ride that far between stops, but having to stop every time at a fuel station sucks.
I also don't quite understand why they don't match their naming strategy to the actual engine size...very misleading.
Voted: Cool
Later.
Unread postPosted: Sat Jul 07, 2012 12:15 pm
My wife's 2009 goes 200 miles (320 km) on a tank in normal mixed riding.
Unread postPosted: Sat Jul 07, 2012 1:26 pm
Years Riding: 20
Voted: Cool
Later.
I agree. I LOVED (absolutely) loved my 2007 Suzuki V-Strom's 22L tank... over 700km range on very, very comfortable bike. Every bike should come with a 400km range IMO and I don't understand the small tank fad either. http://www.totalmotorcycle.com/photos/2 ... rom650.htm
Unread postPosted: Sat Jul 07, 2012 3:52 pm
Years Riding: 2
Funny you should mention the DL...I was just in talking to my salesman about the DL1000...I think it is the next bike for me, but I want to wait to see if they update the bike or not...it has been relatively untouched since introduction in 2002...and the DL650 was updated this year...so...
You obviously had the 650...I think the MT-01 has totally spoiled me for other bikes...the torque is hard to give up...but the DL650 is just such a great bike, it's hard not to consider it.
For now I will have to put up with the 230-250kms range on my bike...but I do like the looks of the BMW more than the Stroms...oh well, can't have it all I guess.
Later.
Unread postPosted: Sat Jul 07, 2012 6:25 pm
Years Riding: 20
Later.
For sure, you should wait and see what Suzuki is going to do with the 2013 Suzuki V-Strom 1000; I'm actually surprised they didn't discountinue it a few years ago (I heard it wasn't selling well vs the 650). But that said, if they do redesign it the offers on the old version DL1000 might just persuade you to go with the 2012... For me, I like the looks of the new re-designed DL650, but would take an older DL650 in a heart beat (bigger gas tank).
I would say the BMW F700GS to me, looks more of a serious off-road bike than the DL650 I had was. The DL650/DL1000 are really designed for "light" off-road use, although I did take my DL650 off-road and it was more to handle off-road than a typical naked bike.
If I had the cash to splash, I would go for the BMW, but it all depends on range and comfort.
Users browsing this forum: dablade, Majestic-12 [Bot], W3C [Validator] and 153 guests
