Total Motorcycle Forums • View topic - Would my bike overheat...
Post new topic Reply to topic  [ 9 posts ]
Unread postPosted: Tue Sep 27, 2011 9:39 am
Real Name: Marc
My Motorcycle: Motomia Enzo 150cc
...If I were to ride say 100km without stopping? Should I let it cool down every now and then or is it fine to ride long distances in one go?
My bike is 150cc, can do about 110kmph and has air cooling.
Dream Bike
2006 Ducati Sport 1000
Unread postPosted: Tue Sep 27, 2011 10:35 am
If it overheats there's something wrong with it.
Unread postPosted: Tue Sep 27, 2011 10:40 am
The longest distance I've traveled without stopping is 210 miles which is about 335 km. ('87 Kawasaki ZG1000) Don't worry, your bike won't overheat as long as air moves over it.
Unread postPosted: Tue Sep 27, 2011 4:31 pm
No as Wrider and John stated, it would not overheat as long as you are moving. That being said...
Couple of caveats here....
1. Since this is a new engine, I would not recommend 100km at sustained throttle as you want the engine to break-in at different rpms. It would be fine once the engine is broken in.
2. This is especially so if this trip requires that you keep the throttle at full for a long period of time to sustain a safe speed (something that is often unavoidable on a 150cc aircooled 4-stroke).
Unread postPosted: Tue Sep 27, 2011 10:40 pm
Real Name: Marc
When would the engine be broken in?
Dream Bike
Unread postPosted: Wed Sep 28, 2011 5:26 am
Didn't you get an owners manual when you bought the bike? Most of the time it's 1000 km change oil and check valve settings. Next service @ 10,000 km.
Unread postPosted: Wed Sep 28, 2011 6:10 am
Real Name: Marc
I just checked the owners manual and it says at 300/1000km I have to replace the oil, clean the oil filter strain and lubricate the clutch and cable, throttle and speedometer cables and the transmission chain and sprocket.
Dream Bike
Unread postPosted: Wed Sep 28, 2011 7:50 am
It doesn't sound like much at all; nothing like checking head bolt torque or valve adjustments. Are you able to do this stuff on your own?
Unread postPosted: Wed Sep 28, 2011 9:22 am
Real Name: Marc
Yes doing it on my own would be no problem.
Dream Bike
Users browsing this forum: dirtcheap, FlyinRegie, Hanson, scooter12 and 72 guests
