Total Motorcycle Forums • View topic - 1984 Honda XR 100 won't start
Unread postPosted: Sat Jul 09, 2011 4:31 am
Real Name: Mark
Years Riding: 20
My Motorcycle: 2008 Vstar 1100 Classic
Hey all have a XR 100 here won't start. When u kick it 4 or 5 times it seems to backfire but more of a phewwwwww sound from exaust. I just bought I trying to get it running. The PO put a new carb in before I bought it. Tried starter fluid and still won't start. Definately spark from spark plug. Any suggestions would be appreciated.
Thanks
Unread postPosted: Sat Jul 09, 2011 5:06 am
Years Riding: 20
Is the carb flooded? Maybe a float is stuck is the carb...when you remove a spark plug does it smell like gas or is the plug contact wet?
2013 Motorcycle Model Guides
2012 Motorcycle Model Guides
2013 ATV/Quad Model Guides
Unread postPosted: Sat Jul 09, 2011 9:52 am
Sounds to me like it's firing 180° out.
Unread postPosted: Sat Jul 09, 2011 11:11 am
Real Name: Mark
Years Riding: 20
no the plug is not wet though when I remove the plug I can smell the gas. I checked the flywheel timing and when its at TDC the piston is at the top. Not sure how else to check the timing. It is a brand new carb. I do have the old carb. When I went to buy it from the PO i kicked it a few times and it did start to idle as soon as I gave it gas it stalled. I figured this would be an easy fix but I am stumped
Unread postPosted: Sat Jul 09, 2011 11:25 am
Check the valves on it.
Users browsing this forum: biker bob 12 and 52 guests
