Total Motorcycle Forums • View topic - 2011 Suzuki Boulevard M109R - COOL WALL VOTE: UNCOOL
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3, 4, 5  Next
VOTE: Your Coolness Factor of the 2011 Suzuki Boulevard M109R is...
Awesome
Cool
Uncool
Fail
View results
Unread postPosted: Fri Apr 29, 2011 2:24 am
Years Riding: 20
http://www.totalmotorcycle.com/photos/2011models/2011-Suzuki-BoulevardM109R.htm
Call it the best of all worlds. Suzuki's award winning Boulevard M109R - an incredible combination of cruiser styling and renowned Suzuki power and handling.
By injecting the Boulevard M109R with a potent shot of race-proven technology developed for the championship-winning GSX-R sport bikes, Suzuki has literally redefined the concept of a cruiser. The Boulevard M109R's exhilarating performance begins with its 109-cubic-inch, fuel injected V-twin engine. It's tuned to produce massive torque all the way from idle to redline, which translates into acceleration that you have to feel to believe - and makes this the most powerful cruiser Suzuki has ever produced.
To reward every one of your senses, the big V-twin also produces a throaty, aggressive exhaust note designed to let the world know they're looking at - and listing to - the hottest cruiser on the road. Like Suzuki's sport bikes, the Boulevard M109R balances extraordinary performance with crisp handling, thanks to a technically advanced chassis and suspension, matched by world-class brakes. And when it comes to wrapping that performance package in cruiser styling, a picture is worth a thousand words.
Check out its sleek, flowing lines and GSX-R inspired styling touches, and you'll realize that the Boulevard M109R is in a class of its own.
The award-winning Suzuki Boulevard M109R recreated the power cruiser market upon its introduction. Its unique style and exhilarating performance – born of championship-winning Suzuki race heritage – have made it the leader in the class.
The Boulevard M109R's exhilarating performance begins with its 109-cubic-inch, fuel injected V-twin engine. It's tuned to produce massive torque all the way from idle to redline, which translates into acceleration that you just have to feel to believe. It’s the most powerful cruiser Suzuki has ever produced. To reward every one of your senses, the big V-twin also produces a throaty, aggressive exhaust note—just what you’d expect from the hottest cruiser on the road.
Like Suzuki's sport bikes, the Boulevard M109R balances extraordinary performance with crisp handling, thanks to a technically advanced chassis and suspension, matched by world-class brakes. And when it comes to wrapping that performance package in cruiser styling, a picture is worth a thousand words. Check out its sleek, flowing lines and GSX-R inspired styling touches, and you'll realize that the Boulevard M109R is in a class of its own.
New for 2011: The M109R features an instrument cluster with a digital tachometer and LED indicator light; a newly included gear position indicator; and it is now relocated from the handlebars to the top of the headlight cowl. In addition the M109R will be available in Candy Indy Blue.
2011 Suzuki Boulevard M109R Features
Key Features
The Boulevard M109R is offered in a new Candy Indy Blue finish.
The Boulevard M109R features a new instrument cluster with a digital tachometer and LED indicator light; a newly included gear position indicator; and it is now relocated from the handlebars to the top of the headlight cowl.
Engine Features
The Boulevard M109R's 1783cc, 8-valve DOHC, 54 degree, liquid-cooled, fuel injected V-twin engine is designed for strong throttle response and quick acceleration.
Suzuki's class-leading electronic fuel injection system features the Suzuki Dual Throttle Valve system (SDTV) with 56mm throttle bodies, which maintains optimum air velocity for smooth low- to mid-range throttle response.
The Boulevard M109R features a massive 112mm bore and 90.5mm stroke, utilizing huge 112mm forged aluminum alloy pistons with short skirts, and cut away sides riding on chrome moly steel connecting rods.
Each engine bore is lined with Suzuki's race proven SCEM (Suzuki Composite Electrochemical Material) for optimum heat transfer, tighter piston-to-cylinder clearances and reduced weight.
A dual spark plug per cylinder ignition system is controlled by the Boulevard M109R's powerful 32-bit ECM for improved combustion efficiency and reduced exhaust emissions.
The Boulevard M109R uses Suzuki Advanced Sump System (SASS), which is a compact dry sump lubrication system that provides reduced engine height, a lower crankshaft position and a lower center of gravity.
A unique two-stage cam drive system creates a compact cylinder head design, reduces overall engine height and creates a lower center of gravity.
The 2-into-1-into-2 stainless steel chromed exhaust system features Suzuki's digitally controlled SET (Suzuki Exhaust Tuning) system for optimum engine performance and a powerful V-twin sound.
The Boulevard M109R has a three piece, 9.5 liter volume airbox (with dual intakes), working through a pleated fabric air cleaner element.
Chassis Features
A high-tensile double cradle steel frame is built to comfortably handle all the power and torque while delivering agile handling and a plush smooth ride.
Inverted front forks featuring race-proven cartridge internals with 46mm stanchion tubes provide 5.12-inches of wheel travel.
A cast aluminum alloy swingarm works with a progressive shock linkage and a preload adjustable single rear shock delivers 4.66 inches of wheel travel working through a shaft drive system.
The Boulevard M109R front brake system includes radial mounted four piston front calipers and 310mm front brake rotors. The rear brake system includes a dual piston caliper and 275mm rear disc.
Spiral spoke cast aluminum alloy wheels measure 3.50 x 18 inch up front and a massive 8.50 x 18 inch rear. The rear wheel wears a huge 240mm rear Dunlop radial tire-the largest ever used on a Suzuki motorcycle.
The Boulevard M109R is equipped with a sleek and wide fuel tank with a 5.2-gallon fuel capacity that flows into integrated side covers; a comfortable low seat; and a stylish radiator cowl.
American Suzuki Motor Corporation makes every effort to present the most current specifications and product features. Because of our policy of continual improvement, changes may be made in equipment, availability, specifications and features without notice or obligation.
2011 Suzuki Boulevard M109R - United States of America Specifications
USA MSRP - $14,099 USD - Canada MSRP - See Dealer for Details
Chassis:
Overall Length 2450 mm (96.5 in)
Overall Width 875 mm (34.4 in)
Wheelbase 1710 mm (67.3 in)
Ground Clearance 130 mm (5.1 in)
Seat Height 705 mm (27.8 in)
347 kg (764 lbs)
Curb Weight
Transmission 5-speed constant mesh
Final Drive Shaft drive
Suspension Front Inverted telescopic, coil spring, oil damped
Suspension Rear Link type, coil spring, oil damped
Brakes Front Disc brake, twin
Brakes Rear Disc brake
Tires Front 130/70R18 M/C 63V tubeless
Tires Rear 240/40R18 M/C 79V tubeless
Fuel Tank Capacity 19.5 L (5.2 US gallons)
Fuel Tank Capacity CA 18.5 L (4.9 US gallons)
Engine:
Displacement 1783cc, 4-stroke, liquid-cooled, DOHC, 54° V-twin
Fuel System Suzuki fuel injection
Starter Electric
Ignition Electronic ignition (transistorized)
Warranty:
Warranty 12 month unlimited mileage limited warranty
2013 Motorcycle Model Guides
2012 Motorcycle Model Guides
2013 ATV/Quad Model Guides
Unread postPosted: Fri Apr 29, 2011 3:22 pm
Real Name: Ben
My Motorcycle: 2002 Kawasaki ZRX1200R
I love muscle cruisers, so I voted Cool, but I could not vote Awesome because of one bike. If this were the VMax I would have voted Awesome.
Unread postPosted: Sat Apr 30, 2011 3:46 am
Real Name: Mark
Indeed, the vmax is cool!!!! I think the vmax should be one for the cool wall!
Unread postPosted: Sat Apr 30, 2011 4:19 am
Real Name: Mark
Okay, great choice! I always looked forward to Friday's cool wall motorcycle! I'm a muscle cruiser fan, although I,m not sure if I would consider it a true muscle cruiser. How many horsepower is it putting out? If it ain't putting well into triple digit hp, it ain't a muscle cruiser IMHO! Anyway, I have a buddy who has one! I love the whole thing except the head light...ugly! So I have to give it a cool vote. Now the m109r2, that would have gotten an awesome vote from me! Actually,the m109r2, I would maybe consider as a replacement for my vrod....well maybe not, but close. My buddy put a 250 rear tire and I believe it comes with a standard 240. All those cruisers should come with a 240 rear tire. I know the handling decreases, but buying a cruiser for handling is like buying a box of donuts to lose weight...just ain't going to happen!
I love the cool wall...the only problem is I think of motorcycles like I think of beer, they all look good when they're sitting in front of me! You all have a great weekend!
Mark
Unread postPosted: Sat Apr 30, 2011 10:11 am
Years Riding: 2
My Motorcycle: wheelchair lately.
I had to vote Uncool, but if there was option between Cool and Uncool I would have definitely used it. Unfortunately, this bike is just a hair more Uncool than Cool. As mentioned by Mark, the headlight is just fugly. I also detest the radiator appearance on these bikes, although I am glad to see that Suzuki has minimized its appearance in profile, which is a huge step forward IMHO. I've never ridden one, but as it is seems to be in nearly direct competition with my Hammer, I'm pretty sure I'd enjoy the ride.
I think what tipped it to the Uncool for me, personally, is the fact that a lot of the shiny parts just look too plasticy for my taste. I've always thought that a cruiser should invoke images of a great steel beast--all attitude and muscle and rip-snort power. Too many of those parts look like they're more rip-off than rip-snort.
Unread postPosted: Sat Apr 30, 2011 2:15 pm
Years Riding: 20
I voted: COOL
I really like how Suzuki brought in the "Sport Bike styling" into the cruiser mix. Not a lot of Cruisers out there have mixed that successfully as the M109R. I like the gauges, I like the two tone paint job, I like the streamlining of the bike and the flow of it's design as well. I know jaskc78 mentioned a negative about the radiator cowl, but doesn't it look much better (more integrated) than the V-Rod's version? It's a BIG radiator so there is no hiding it, unfortunately.
The headlight and the bike's bulk really stop me from giving it an Awesome vote. I've sat on it and it's bulky although comfortable.
Suzuki says it best with "Like Suzuki's sport bikes, the Boulevard M109R balances extraordinary performance with crisp handling, thanks to a technically advanced chassis and suspension, matched by world-class brakes"
If I had to go with a M series Suzuki Boulevard it would be the looks of the previous edition M50, I just like the tail better (always chasing tail it seems...haha) but the M109R is a close second for looks... can I just get one a little less top heavy?
COOL bike, especially in the blue and silver.
It will be interesting how the vote swings on this one in the end.
Unread postPosted: Sat Apr 30, 2011 2:40 pm
Years Riding: 2
Yeah, I like the two-tone paint as well, and the color-matched frame (unless that's just a cover on the visible bits). I gotta agree with you on the tail, Mike--I'm a huge fan of bobbed rear fenders (where the fender actually extends out above the tail light). And yeah, the radiator is a huge improvement over previous years and the side covers on it flow a LOT better with the lines of the bike, I just personally prefer the cleaner look of a bike without a radiator at all, and would like to see them trim back the pieces that extend out and look like they'd deflect air away from the engine. Again, the cleaner look, but from a pragmatic standpoint it'd help with keeping the engine cool when you're moving.
If I was comparing it to past M109's, this bike would be an awesome for sure. Comparing it to what I like and look for in bikes and to all other cruisers, I stand by my mixed Cool and Uncool with just a tad more Uncool tipping the scales.
Unread postPosted: Sat Apr 30, 2011 6:49 pm
Years Riding: 31
My Motorcycle: '07 HD FLTR/Ranger combo
Meh... mediocre styling, useless "fairing", awkward ergonomics, bizarre dash layout and no thought given to passenger accomodation and too much chromed plastic. The Yamaha V-Max nailed the muscle bike genre, the Triumph Speed Triple has the hooligan bike crown and the Triumph Rocket III has the biggest, um, manly bits. The M-109 comes across as the two wheeled equivalent of the "Fast and Furious" boompa-boompa car to me.
:canada: Mike :gummiente:
'07 Road Glide/Texas Sidecars "Ranger"
The Blackbird Stealth Bomber
Unread postPosted: Sun May 01, 2011 7:19 am
My Motorcycle: VFR1200, SuperDuke 990
I always liked the M-109 even though I'm not real a cruiser guy. I had never knew that there was an M109R2 and after looking it up it looks pretty great in my opinion as well. I'm pretty sure that I have never seen one on the street in Canada however.
HighSides Trips and Pics
Unread postPosted: Sun May 01, 2011 1:35 pm
Years Riding: 20
I haven't seen too many M109's on the roads either (they do have them in the UK for sale as well... here they are called the:
Suzuki Intruder M1800RZ
I can't really see them as a viable option on british roads and traffic... Imagine not being able to lane spit (filter) when everyone else on a motorcycle is...
Users browsing this forum: BobK, montanalifter, snakedoctEr726 and 178 guests
