Total Motorcycle Forums • View topic - 2011 Norton Commando 961 Sport - COOL WALL VOTE: AWESOME
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2, 3  Next
Your Coolness Factor of the 2011 Norton Commando 961 Sport is...
Awesome
Cool
Uncool
Fail
View results
Unread postPosted: Fri Jan 21, 2011 7:48 am
Years Riding: 20
http://www.totalmotorcycle.com/photos/2011models/2011-Norton-Commando961Sport.htm
Frame
- Frame: Steel tubular with integral oil tank
- Swing arm: Twin-sided steel construction
- Wheelbase: 1420mm (55.9 in)
- Rake: 24.5 degrees
- Trail: 99mm (3.9 in)
- Front suspension: 43mm Ohlins RWU - Adjustable preload, compression damping.
- Rear suspension: Ohlins reservoir-style twin shocks - Adjustable ride height, preload, compression
- Front wheel: 36 spoke 3.50 x 17” Chrome Rim
- Rear wheel: 40 spoke 5.0 x 17” Chrome Rim
- Front tyre: 120/70 x 17”
- Rear tyre: 180/55 x 17”
- Front wheel travel: 115mm (4.53 in)
- Rear wheel travel: 100mm (3.94 in)
Brakes & Hydraulics
- Front brakes: Full Brembo system, twin Brembo 320mm semi-floating hi
carbon stainless steel discs, Brembo 4 piston “Gold Line” axial callipers
- Rear brakes: Full Brembo system, single Brembo 220mm disc, Brembo 2 piston “Gold Line” calliper
- Brembo “Gold Line” front brake master cylinder
- Brembo “Gold Line” hydraulic clutch master cylinder
- Brembo rear brake master cylinder
- Brembo hydraulic clutch actuation slave cylinder
Transmission
- Gear box: constant mesh 5 speed
- Final drive: 525 “O” ring chain
- Clutch: Wet multi-plate hydraulic lifter
- Electric start Power Assembly
- Engine type: New engine developed by Norton and F1 engine builders, MCT of Oxfordshire, England. Parallel twin with push-rod valve actuation, dry sump, 3 bearing crank and balancer shaft.
- Displacement: 961cc
- Cooling system: Air
- Valve actuation: Push rod, 2 valves per cylinder
- Bore x stroke: 88mm x 79mm
- Compression ratio: 10.1:1
- Power: 80PS @ 6500RPM
- Torque: 90Nm @ 5200RPM
- Ignition: Crank fired electronic
- Euro 3 compliant with electronic fuel injection and multiple 3 way catalytic converter
Electronics & Controls
- Charging system: 300 watt hi-output charging system
- Instrumentation: Norton electronic analogue speedo & tachometer
Miscellaneous
- Fuel tank capacity: 17 litres (4.5 US gallon)
- Dry weight: 188kg (414.5 lbs)
- Seat height: 813mm (32 in)
- Steering: Fully machined billet yokes, triple clamp lower yokes
- Handlebars: Tubular steel in chrome
Colour Options
- Black & Gold
- Red & Gold
- Yellow & Black
- Silver, Red & Black
2013 Motorcycle Model Guides
2012 Motorcycle Model Guides
2013 ATV/Quad Model Guides
Unread postPosted: Fri Jan 21, 2011 10:48 am
My Motorcycle: VFR1200, SuperDuke 990
Nice bike but for a projected Canadian MSRP of >$20K I can get a lot more for the money. They will need to work on their price point if they are going to make a serious go of it.
HighSides Trips and Pics
Unread postPosted: Fri Jan 21, 2011 11:07 am
Years Riding: 20
I have the official last years (2010 model for the SE that is sold in the USA/Canada) prices I requested from Norton:
2010 Norton Commando 961 SE
MSRP: $17,899 USD
2010 Norton Commando 961 Sport
MSRP: £11,995 GBP - Price shown includes the 'On the Road' costs and VAT for the UK.
Price: £12,495 GBP - Price shown includes the 'On the Road' costs and VAT for the UK.
If I compare that to say a Ducati streetfighter (as I think Norton is right there with that quality)
2011 Ducati Streetfighter
USA MSRP - $14,995 USD
UK MSRP - Starting from £11,750
I would say if it's at $19,999 (GBP £ price seems identical though) it isn't that bad of a deal as they are definately not making as many bikes as Ducati is, but looking at the bike (and I got to sit on the 2010 and 2011's) quality is right high with fit and finish. If Norton starts to ramp up production, I can see them going for the same as Ducati's in the future...
But I am with you, I would like to see them lower in price... but what is the trade off?
BTW - Did you vote?
Unread postPosted: Fri Jan 21, 2011 11:52 am
MSRP: $17,899 USD
BTW - Did you vote?
I don't think you are accurate in comparing this to a Ducati Streetfighter that has far more refined engineering, an additional 40-50 hp and the chassis to match. The Monster 1100 would be a much better comparison and it would still be superior to the Norton IMO. And even with the $Can at par with the $US you can still be sure that the bike will be north of 20K when it comes to Canada if most other bikes are any indication. It's a nice bike, but I really don't think that you get what you pay for.
Unread postPosted: Fri Jan 21, 2011 12:38 pm
Years Riding: 20
"and the games afoot!"
(that would be Sherlock Holmes' language)
Unread postPosted: Fri Jan 21, 2011 5:39 pm
As far as comparing it with a Ducati I'd say it looks more like a GT 1000 than anything else and I don't know what they sold for but the price on the Norton is way high. The styling is top notch and the fact that they're using Brembo brakes and Ohlins suspension seems to scream high end but the power train is unproven at this point as far as reliability goes. Anyway, it's not gonna happen but I'd love to be the first kid on the block to get one.
Unread postPosted: Fri Jan 21, 2011 7:08 pm
I think that you are bang on with the GT and the differences in brakes and suspension (I used to own but but tend to block it out as I hated it). One of the biggest weaknesses of the GT was the suspension. To outfit the GT that was about 13K to start with, with Ohlins suspension would cost you about $2.5K. Ad another 2K for the Termingoni cans and ECU to make it run acceptably (a must, as stock it fueled terribly) and the price is creeping up there. But then, that's why I unloaded mine :| Too much cash for what you get.
It was nice looking though....
Unread postPosted: Fri Jan 21, 2011 7:13 pm
Don't forget the expanding fuel tank. :laughing:
Unread postPosted: Fri Jan 21, 2011 11:19 pm
How could I? I still have one in the garage!
Unread postPosted: Sat Jan 22, 2011 5:08 pm
Real Name: Ben
My Motorcycle: 2002 Kawasaki ZRX1200R
I voted cool, the price and availability keep it from being Awesome for me.
The more I look at it the more I wish I had voted awesome just for the looks, (maybe price should only come into effect if I were going to buy it) and my nephew said it was Awesome.
Users browsing this forum: jstark47, montanalifter, MSN [Bot], snakedoctEr726, storysunfolding, Wrider, ZRex and 173 guests
cron
