1981 Laverda Alpino 500
Back to Laverda Motorcycle Specs Index Page
Click Here to Compare upto 4 Motorcycle Models
– 1981 Laverda Alpino 500
MANUFACTURER SPECIFICATIONS
Manufacturer – Make – Model – Year: Laverda Alpino 500 1982
Motorcycle Style: Standard
ENGINE SPECS
Engine Type: 497 cc, 4-Stroke, Air Cooled, Parallel Twin
Engine Bore and Stroke: 72 mm x 61 mm
Valves 4 valves/cylinder
Claimed Horsepower: 44 hp (32.8 kW) @ 8000 rpm
Transmission type: 6 speed
Final Drive: Chain
MISCELLANEOUS SPECS
Tire – Front: 90/90-17
Tire – Rear: 110/90-18
Brakes – Front: dual 260 mm discs with 2-piston calipers
Brakes – Rear: single 260 mm disc with 1-piston calipers
DIMENSIONS
Fuel Capacity: 14 l (3.7 Gal)
Dry Weight (without fluids): 175 kg (385.8 pounds)
2026 Newest Bike Reviews
TMW 2026 Motorcycle Model Review Guides
Be the first to comment
Leave a Reply
