2016 Suzuki Boulevard M109R BOSS
Published November 19, 2016 by , Editor‑in‑Chief
Back to the 2016 Suzuki Motorcycle Model Review Page
Click photos to enlarge. Our big, clean bike pics make great desktop wallpaper.
2016 Suzuki Boulevard M109R BOSS Review
2016 Suzuki Boulevard M109R BOSS on www.Totalmotorcycle.com
Born to Ride…
With capabilities born of Suzuki’s Performance DNA heritage, the M109R B.O.S.S. is a power cruiser using some of the largest pistons in the industry — a bike that will get your adrenaline flowing whenever you ride. Featuring aggressive blacked-out styling, it delivers awesome performance and massive amounts of torque from idle to redline. That’s complemented by smooth performance on the highway and precise, agile handling provided by its rigid chassis and inverted forks.
Go ahead and admit it, you want to be the owner of the most stylish bike on the block. Lucky for you, the Suzuki Boulevard M109R B.O.S.S. grabs attention everywhere it goes. An incomparable black color scheme coupled with aggressive styling scream in testament to the M109R’s power. If looks aren’t enough to sell you on this bike, then let the 1783cc V-Twin engine convince you. Tuned to produce massive torque from idle to red-line, the 2015 Suzuki Boulevard M109R B.O.S.S. will keep you smiling and styling through your journeys to come.
Without question, the M109R B.O.S.S. delivers unparalleled performance and gorgeous styling to own the night. The M109R B.O.S.S. features an advanced chassis built for effortless cruising across town, or across state lines. Its unrivaled capabilities are born from Suzuki’s championship-winning race heritage. The M109R’s engine is tuned to produce massive torque all the way from idle to redline, which translates into acceleration that you have to feel to believe. The big V-twin also produces a throaty, aggressive exhaust that identifies the M109R B.O.S.S. as a power cruiser beyond compare.
2016 Suzuki Boulevard M109R BOSS www.Totalmotorcycle.com Key Features
The M109R B.O.S.S. (Blacked Out Special Suzuki) features the following:
1. Blacked-out exhaust system, clutch cover, magneto cover, cylinder head covers, air cleaner cover and final drive case.
2. Blacked-out handlebars, clutch and brake levers, handlebar switch cases, rear view mirrors, fuel tank/instrument cover, front and rear wheels, front and rear brake calipers, frame side covers, rear fender stays, side-stand, steering stem clamps and front forks.
3. Clear taillight and turn signal lenses.
2016 Suzuki Boulevard M109R BOSS www.Totalmotorcycle.com Features and Benefits
A 1783cc, 8-valve DOHC, 54-degree, liquid-cooled, V-Twin engine is designed to produce a massive tractable power and responsive torque.
Huge 4.4 inch (112mm) forged aluminum-alloy pistons. These are one of the largest reciprocating gasoline engine pistons being used in any production passenger car or motorcycle, while featuring race-proven design to reduce friction and inertial mass.
Each large cylinder bore is lined with Suzuki’s race proven SCEM (Suzuki Composite Electrochemical Material) for optimum heat transfer, tighter piston-to-cylinder clearances and reduced weight.
Suzuki Advanced Sump System (SASS), a compact dry sump lubrication system, provides reduced engine height, a lower crankshaft position and a lower center of gravity.
Suzuki’s class-leading electronic fuel injection system features the Suzuki Dual Throttle Valve system (SDTV) with 56mm throttle bodies, which maintains optimum air velocity for smooth low to mid-range throttle response.
A unique two-stage cam drive system creates a compact cylinder head design, reduces overall engine height and creates a lower center of gravity.
A dual spark plug per cylinder ignition system is controlled by a powerful 32-bit ECM for improved combustion efficiency and reduced exhaust emissions.
A three-piece, 9.5-liter volume airbox (with dual intakes) includes two pleated fabric air cleaner elements located on both sides of the engine.
The 2-into-1-into-2 stainless steel blacked-out exhaust system features Suzuki’s digitally controlled SET (Suzuki Exhaust Tuning) system for optimum engine performance and a powerful V-Twin sound.
Sculpted engine features blacked out engine covers that complement the visually striking cylinders with symmetrical, high-lighted cooling fins.
A wide-ratio, constant-mesh five-speed transmission features a high fifth gear ratio for relaxed highway cruising.
Low-maintenance shaft drive is clean-running and has minimal torque reaction as it efficiently transmits power to the massive 18-inch rear tire.
CHASSIS FEATURES
A high-tensile double cradle steel frame is built to comfortably handle all the power and torque while delivering agile handling and a plush, smooth ride.
The massive 240/40 x 18 is the widest rear tire ever used on a SUZUKI motorcycle.
Blacked-out, inverted front forks feature race-proven cartridge internals with 46mm stanchion tubes and provide 5.1-inches of smooth wheel travel.
Cast aluminum-alloy swingarm works with a progressive linkage and a single rear shock absorber; adjustable spring preload to suit rider and passenger weight.
Twin front fully-floating disc-brakes with dual-piston calipers and a single-disc, rear brake with a single dual-piston caliper are ready to haul the bike down from speed.
Flat-bend, drag-style handlebars are mounted on pull-back risers to be positioned within a short distance from the seat to improve the rider/machine interface, aiding comfort and control.
The long-stretch fuel tank holds a full 4.9 gallons of fuel.
Tank-mounted analog speedometer and LCD odometer, dual tripmeters, fuel gauge and clock.
Instrument cluster including a digital tachometer, gear position indicator and LED indicator lights is integrated into the top of the headlight cowl.
Both rider and passenger seats are made for comfort as they allow freedom of movement and accommodate riders of di?erent sizes, and are well cushioned.
A sporty solo-seat cover (included) can be quickly swapped for the passenger seat for an even more aggressive look or for use on solo rides.
ADDITIONAL FEATURES
Genuine Suzuki accessory options for the M109R B.O.S.S. include a black-finish engine guard set and trim-fitting, functional saddlebags.
A variety of Genuine Suzuki Accessories for Boulevard owners are available including a large selection of Suzuki logo apparel.
12-month limited warranty
2016 Suzuki Boulevard M109R BOSS – www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $14999 USD
ENGINE
Engine 1783cc, 4-stroke, liquid-cooled, DOHC, 54-degree V-twin
Bore x Stroke 112.0 mm x 90.5 mm (4.41 in x 3.56 in)
Compression Ratio 10.5 : 1
Fuel System Fuel Injection
Starter Electric
DRIVE TRAIN
Transmission 5-speed constant mesh
Final Drive Shaft Drive
CHASSIS
Suspension Front Inverted telescopic, coil spring, oil damped
Suspension Rear Link type, oil damped, coil spring
Brakes Front Disc, twin
Brakes Rear Disc
Tires Front 130/70R18 M/C 63V tubeless
Tires Rear 240/40R18 M/C 79V tubeless
Fuel Tank Capacity 19.5 L (5.2 US gallons), 18.5 L (4.9 US gallons) CA model
Color Pearl Vigor Blue / Glass Sparkle Black, Metallic Matte Fibroin Gray
ELECTRICAL
Ignition Electronic ignition (Transistorized)
DIMENSIONS
Overall Length 2450 mm (95.5 in)
Overall Width 875 mm (34.4 in)
Wheelbase 1710 mm (67.3 in)
Ground Clearance 130 mm (5.1 in)
Seat Height 705 mm (27.8 in)
Curb Weight 347 kg (764 lbs)
WARRANTY
Warranty 12 month unlimited mileage limited warranty.
2016 Suzuki Boulevard M109R BOSS – www.Totalmotorcycle.com Canadian Specifications/Technical Details
Canada MSRP Price: $16499 CDN
ENGINE
Type 4-stroke, 2-cylinder, liquid-cooled, DOHC, 54-degree V-Twin
Displacement 1783 cc (108.8 cu. in)
Bore x Stroke 112.0mm x 90.5mm
Starter Electric
DRIVETRAIN
CHASSIS
Overall Length 2480 mm (97.6 in)
Overall Height 1130 mm (44.5 in)
Curb Mass 347 kg (764 lbs)
Suspension Rear Link type, coil spring, oil damped
Brakes Rear Disc
Tires Front 130/70R18M/C 63V, tubeless
Tires Rear 240/40R18M/C 79V, tubeless
Ignition Type Electronic ignition (Transistorized)
Fuel Tank 19.5L (5.2 US gal)
WARRANTY
Standard Warranty 12 Month unlimited mileage limited warranty
2016 Suzuki Boulevard M109R BOSS – www.Totalmotorcycle.com European Specifications/Technical Details
Europe/UK MSRP Price: £ GBP (On The Road inc 20% Vat)
NA
Manufacturer Specifications and appearance are subject to change without prior notice on Total Motorcycle (TMW).
2026 Newest Bike Reviews
TMW 2026 Motorcycle Model Review Guides
Be the first to comment
Leave a Reply
