2007 Harley-Davidson FLHTCUSE2 Screamin’ Eagle Ultra Classic Electra Glide
Posted on September 17, 2016 by Michael Le Pard
You are here: HomeNew 2007 Models — 2007 Harley-Davidson Motorcycle Models
Back to 2007 Harley-Davidson Motorcycle Index Page
Click photos to enlarge.
They make great desktop images.
2007 Harley-Davidson FLHTCUSE2 Screamin' Eagle Ultra Classic Electra Glide
– 2007 Harley-Davidson FLHTCUSE2 Screamin’ Eagle Ultra Classic Electra Glide
FLHTCUSE2 Screamin’ Eagle® Ultra Classic® Electra Glide® Model Overview
Harley-Davidson Custom Vehicle Operations (CVO) offers touring riders thrilling performance and unmatched luxury in 2007 with the introduction of the FLHTCUSE2 Screamin’ Eagle Ultra Classic Electra Glide. Powered by a new Twin Cam 110 engine paired with the 6-speed Cruise Drive transmission, the Screamin’ Eagle Ultra will roll down the highway with authority. Styling is updated with a new paint scheme and the new Ironside controls collection, while new convenience features include electric luggage locks and a navigation system.
Features of the 2007 FLHTCUSE Screamin’ Eagle Ultra include:
Custom colors:
Black Ice and Electric Orange
Lightning Blue Pearl and Midnight Pearl
Light Candy Cherry and Black Ice
Color-matched vented fairing lowers with storage compartments, inner fairing and switch panel and saddlebag filler strips
Custom leather Tour-Pak styled with custom leather braiding and stitching including LED interior light, luggage rack and lumbar support passenger backrest
Plush Tour-Pak, glove box and saddlebag liners
Custom leather dash pad with chrome accent
Twin Cam 110 Powertrain finished in Black and Chrome
Screamin’ Eagle SYN3 Synthetic Lubricant
Black high-torque 1.4 kW starter
High-performance clutch with hydraulic actuation
Custom oil cooler with chrome cover
Custom voltage regulator
Chrome billet timer cover
Derby covers with color-filled script
Ribbed air cleaner cover with Screamin’ Eagle insert
Chrome 9-Spoke Cast Aluminum wheels
Chrome front custom floating brake discs
Silver brake calipers with billet-style inserts
Chrome front axle covers
Chrome fork sliders and chrome upper fork covers
Chrome lower triple tree cover
Chrome custom passing lamp brackets with bullet-style front turn signal
Smoked turn signal lenses with amber bulbs
Electra Glide lightly smoked low windshield and matching air deflectors
Spun aluminum metal-faced speedo, tachometer and two-inch auxiliary gauges with backlighting
Advanced Audio System by Harman/Kardon
AM/FM/XM radio
CB/Intercom
Amplifier
Navigation system
Front and rear speakers
Chrome one-inch diameter handlebar with internal wiring
Chrome clutch and brake master cylinders
Chrome switch housings and hand levers
Chrome mirrors
Cruise control
Clear-coated, braided stainless steel control cables, front brake and clutch lines
Chrome CB pod with color-matched inserts
Chrome extended-reach billet brake lever
Chrome billet heel/toe shift levers
Polished stainless steel hex shift linkage
Chrome rider footboard supports and adjustable passenger footboard supports
Stealth Collection rider and passenger footboard pans
Ironside Collection:
Rider and passenger foot board inserts
Heated grips and grip end caps
Brake pedal pad
Shifter pegs
Highway pegs
Custom leather dual control heated seat
Adjustable rider backrest
Chrome saddlebag cover trim
Chrome valve cover stem caps
Chrome front wheel bearing spacers
Chrome four-inch Touring mufflers with chrome billet end caps
Chrome Touring muffler shields
Integral garage door opener and receiver
Powered saddlebag and Tour-Pak locks
Carryout saddlebag and Tour-Pak liners
Harley-Davidson Smart Security System
Indoor storage cover with embroidered CVO logo
Commemorative CVO ignition key with box
SPECIFICATIONS:
Dimensions
Length 96.7 in. (2456.0 mm)
Overall Width 38.2 in. (969.0 mm)
Overall Height 57.1 in. (1450.0 mm)
Seat Height:
– Laden2
– Unladen
28.1 in. (713.0 mm)
29.3 in. (743.0 mm)
Ground Clearance 6.0 in. (152.0 mm)
Rake (steering head) 26°
Fork Angle 29.3°
Trail 6.2 in. (157.5 mm)
Wheelbase 63.5 in. (1612.9 mm)
Tires (Dunlop® Harley-Davidson Series, bias blackwall):
– Front – D402F NW
– Rear – D402 NW
MT90B16 72H
MU85B16 77H
Fuel Capacity 5.0 gal. (18.9 L)
(warning light at approximately 1.0 gal.)
Oil Capacity 4.0 qts. (3.8 L)
Transmission Capacity 1.0 qts. (0.95 L)
Primary Chain Case
Capacity3
1.4 qts. (1.3 L)
Weight:
– As Shipped
– In Running Order
– Gross Vehicle Weight
Rating
– Gross Axle Weight Rating
– Front
– Rear
859 lbs. (390 kg)
888 lbs. (403 kg)
1259 lbs. (572 kg)
500 lbs. (227 kg)
827 lbs. (375 kg)
Engine
Engine Air-cooled, Twin Cam 110TM
Valve Train Pushrod-operated, overhead valves
with hydraulic, self-adjusting lifters;
two valves per cylinder
Bore x Stroke 4.00 in. x 4.38 in. (101.60 mm x 111.13 mm)
Displacement 110 cu. in. (1800 cc)
Compression Ratio 9.3:1
Fuel System3 Electronic Sequential Port Fuel Injection
(ESPFI)
Air Cleaner Chrome, ribbed oval cover with
high-efficiency, pleated paper filtration
Lubrication System Pressurized, dry-sump
Drivetrain
Primary Drive Chain, 34/46 ratio
Final Drive9 Belt, 32/66 ratio
Clutch Hydraulically actuated, 9-plate, wet with
high performance spring
Transmission 6-speed Cruise Drive™
Gear Ratios (overall):
– 1st
– 2nd
– 3rd
– 4th
– 5th
– 6th
U.S. HDI
9.312 9.312
6.421 6.421
4.774 4.774
3.926 3.926
3.279 3.279
2.790 2.790
Chassis
Frame Mild steel, square-section backbone with
twin downtubes
Swingarm Mild steel, rectangular tube sections,
stamped junctions; MIG welded
Front Fork 41.3 mm telescopic, cartridge-style damping
Rear Shocks Air-adjustable
Wheels4 Chrome, 9-spoke Cast Aluminum
– Front
– Rear
16 in. x 3.0 in. (406.4 mm x 76.2 mm)
Brakes:
– Caliper Type
– Rotor Type (diameter x width):
– Front (dual)
– Rear
4-piston front and rear
Chrome, floating brake rotors
11.5 in. x .20 in. (292.1 mm x 5.08 mm)
11.5 in. x .23 in. (292.1 mm x 5.84 mm)
Suspension Travel:
– Front Wheel
– Rear Wheel
4.6 in. (116.8 mm)
3.0 in. (76.2 mm)
Performance
Engine Torque (per SAE J1349)5:
– North America
– World
115 ft. lbs. @ 3000 rpm (156 NM @ 3000 rpm)
104 ft. lbs. @ 4200 rpm (142 NM @ 4200 rpm)
Lean Angle (per SAE J1168): Right: 32° Left: 30°
Fuel Economy10
(EPA urban/highway test)
37.7/53.5 mpg (6.23/4.39 L/100 km)
Electric
Battery (per Battery Council
International Rating)
Sealed, maintenance-free, 12V,
28-amp/hour, 270 cca
Charging Three-phase, 50-amp system
(585W @ 13V, 2000 rpm, 650W max power @ 13V)
Starting 1.4 kW electric with solenoid shift starter
motor engagement
Lights (as per country regulation):
– Headlamp (dual bulb halogen)
– Passing Lamps
– Tail/Stop Lights
– Turn Signal Lights
– Indicator Lamps
55-watt low beam, 35-watt high beam
Sealed beam, two @ 27W each
(except where prohibited by law)
8W/28W (5W/21W)
28W (21W) self-canceling
High beam, neutral, low oil pressure,
engine diagnostics, turn signals, low fuel
warnings, cruise control, battery, security
system,6 6-speed
Styling / Convenience
Engine Trim Black powder-coated with chrome treatment
Exhaust System Chrome, 4-in. Touring cross-over duals
Handlebars Chrome, 1-in. diameter internally wired bars;
Ironside Collection heated handgrips w/
chrome endcaps
Seat One-piece, two-up custom leather dual
control heated seat with adjustable rider
backrest
Fairing Fork-mounted “bat-wing”
Inner Fairing Color-matched with custom leather and
chrome accented dash pad
Lower Fairings Color-matched with adjustable vents
Fairing Air Deflectors Lightly smoked fairing-mounted deflectors
Glovebox (2) inside fairing lowers w/ liners and covers
Instruments Spun-aluminum, metal-faced w/ backlighting;
electronic speedometer/tachometer, fuel
gauge, voltmeter, low oil pressure gauge,
sound system w/ handlebar controls,
ambient air temperature gauge, odometer
and resettable tripmeter, cruise control
Stereo Premium system (40W per speaker) w/ AM/FM/
CD MP3 player; XM Satellite Radio; navigation
system, front/rear speakers, amplifier, weather
band, clock, bi-directional seek/scan, track
search/scan, 8 presets and automatic volume
control w/ adjustable sensitivity
Auxilliary Audio Input On radio face; will accomodate any
line-level audio output device
XM® Satellite Radio 3-month trial of XM Satellite Radio service
Antenna AM/FM/WB and CB antennas
Intercom Push-to-talk or voice-activated
CB 4-watt, 40-channel electronically-tuned CB
(prohibited in some countries) w/ passenger controls
Headset/Headset
Receptacles
Driver/passenger stereo receptacle (use restricted
in some states/countries), single headset included
Custom Leather
Tour-Pak®
Luggage box style w/ custom leather
braiding/stitching; LED interior light, luggage
rack, passenger backrest; plush liner
Saddlebags Injection-molded GTX® with hinged lid,
chrome cover trim/slant latches; plush liners
Removable Liners Removable saddlebag and Tour-Pak liners
Saddlebag Filler Strips Color-matched saddlebag filler strips
Luggage/Fork Locks Saddlebag/Tour-Pak power locking system
with barrel key; common with ignition key
Gas Cap Chrome push-button fuel door
Front Lighting Custom passing lamp brackets w/ bullet-style
turn signals; smoked lenses w/ amber bulbs
Rear Lighting Bullet-style rear signals; chrome narrow bar
Hazard Warning Integrated into turn signal controls
Smart Security System6 Next-generation hands-free security fob;
operates based on proximity to vehicle;
factory installed with Smart Siren II
Colors11
Black Ice/Electric Orange (new), Light Candy Cherry/Black Ice (new),
Lightning Blue Pearl/Midnight Pearl (new)
Warranty
Warranty7 24 months (unlimited mileage)
Service Interval First 1,000 miles (1,600 km),
every 5,000 miles (8,000 km) thereafter8
1 Harley-Davidson reserves the right to discontinue models or change specifications at
any time without incurring any obligations. Vehicle specifications may vary by country
and region depending on local laws. Some models are not available in certain countries.
2 Measurement reflects 180 lb. (81.7 kg) operator weight.
3 Recommended 91 octane or higher fuel (R+M)/2 (87 octane or higher for XL 883
models). Standard and optional fuel systems may vary by country and region.
4 Standard and optional wheels may vary by country and region.
5 Values shown are nominal. Performance may vary by country and region.
6 North America and HDI security systems include immobilizer and siren.
7 See motorcycle owner’s manual for complete details.
8 Inspections of certain systems and components are required at 2,500 mile (4,000 km) intervals.
9 U.S. and HDI markets, except Japan: Belt 32/64 ratio.
10 Estimated from fuel economy tests on a sample motorcycle from the corresponding
family conducted by Harley-Davidson under ideal laboratory conditions. Not all
motorcycle models undergo fuel economy testing. Fuel economy and mileage may vary
among motorcycle models within a family. Your mileage may vary depending on your
personal riding habits, weather conditions, trip length, vehicle conditions, and vehicle
configuration and other conditions. Break-in mileage may vary.
11 Availability may vary from dealer to dealer, and is subject to change without notice.
2026 Newest Bike Reviews
TMW 2026 Motorcycle Model Review Guides
Be the first to comment
Leave a Reply
