Total Motorcycle Forums • View topic - 2012 Triumph Sprint GT: Voted Cool
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
Your Coolness Factor of the 2012 Triumph Sprint GT is...
Awesome
Cool
Uncool
Fail
View results
Unread postPosted: Fri Jun 22, 2012 1:35 pm
Years Riding: 20
More photos and information: http://www.totalmotorcycle.com/motorcycles/2012models/2012-Triumph-SprintGT.htm
For all the roads ahead.
The perfect all rounder. Built for your lifestyle. Two up or solo, loaded or light, the Sprint GT takes it all and delivers a fast and stable GT experience in a value for money package.
Triumph spoke to many sports touring riders when developing the Sprint GT, including many Sprint ST owners. The result is a package that delivers all that is good about the ST, updated and incorporating a number of features aimed at improving practicality and mile eating capabilities. A classic British GT.
The New Sprint GT. All round entertainment.
Designed by long-distance riders for long-distance riders. That’s why the GT has the 1050cc triple renowned for power, reliability and soul. That's why the GT has a fuel tank that'll cover 200 miles. That's why the GT has an uprated headlight an extended swing arm for better stability and that's why the GT has up to 117 liters of luggage capacity with an accessory top box including 12v electronics.
Sport or Touring? How about both with the supremely versatile Sprint.
Sprint ST. 1050 engine, mile eating capacity, bags of torque, comfort and plenty of "go".
Sprint GT. Power, handling, practicality and versatility in equal measure.
Fuel Efficiency:
40 MPG City / 59 MPG Highway
Performance:
Triumph's 1050cc triple engine uprated and good for 128bhp as well as 80ft.lbs of torque. The new ECU helps deliver smoother throttle response, more power and torque and improved fuel consumption. A 200 mile fuel range for more time between stops. The new ECU helps deliver smoother throttle response, more power and torque and improved fuel consumption.
Handling and Comfort:
With the same twin-spar aluminium beam frame as the ST, plus uprated internals and a new chassis, the new Sprint GT combines Sports bike performance with two up all day touring comfort.
Practicality:
Underseat storage with space for a u-lock. Built in rack and grab handle. 200 mile fuel range. World class luggage handling with 31 litre helmet-swallowing panniers as standard. The Sprint GT is as practical as you need.
Even More Practicality:
Triumph's Accessories division offers a full range of accessories for you to create your own GT. Start with a colour coded and powered top box. Check out the seating options, heated grips and taller aero screen.
2012 Triumph Sprint GT - US Specifications/Technical Details
USA MSRP Price: On The Road $13,399
Canada MSRP Price: On The Road $14,699
Engine and Transmission
Type Liquid-cooled, 12 valve, DOHC, in-line 3-cylinder
Capacity 1050cc
Bore/Stroke 79 x 71.4mm
Fuel System Multipoint sequential electronic fuel injection with SAI
Exhaust Stainless steel 3 into 1, side mounted stainless steel exhaust
Final Drive X ring chain
Clutch Wet, multi-plate
Gearbox 6-speed
Oil Capacity 3.5 liters (0.9 US gals)
Chassis, Running Gear and Displays
Frame Aluminum beam perimeter
Swingarm Single-sided, aluminium alloy with eccentric chain adjuster
Wheel Front Cast aluminum alloy 5-spoke 17 x 3.5in
Rear Cast aluminum alloy 5-spoke 17 x 5.5in
Tire Front 120/70 ZR 17
Rear 180/55 ZR 17
Suspension Front Showa 43mm cartridge forks with dual rate springs and adjustable preload, 127mm travel
Rear Showa monoshock with adjustable preload and rebound damping, 152mm rear wheel travel
Brakes Front Twin 320mm floating discs, Nissin 4-piston calipers, ABS
Rear Single 255mm disc, Nissin 2-piston sliding caliper, ABS
Instrument Display/Functions Analogue speedometer, trip computer, clock and analogue tachometer
Dimensions and Capacities
Length 2260 mm (88.9 in)
Width (handlebars) 760 mm (29.9 in)
Height without mirrors 1210 mm (47.6 in)
Seat Height 815 mm (32.1 in)
Wheelbase 1537mm (60.5 in)
Rake/Trail 23.5.0º / 84mm
Fuel Tank Capacity / Efficiency 20 liters (5.3 US gals)
Wet Weight (ready to ride) 265 kg (583 lbs)
Performance (measured at crankshaft to 95/1/EC)
Maximum Power 130PS / 128bhp / 96 kW @ 9200rpm
Maximum Torque 108Nm / 80 ft.lbs @ 6300rpm
Fuel Efficiency 40 MPG City / 59 MPG Highway *Estimated from fuel economy tests on a sample motorcycle conducted under ideal laboratory conditions. Actual mileage may vary based upon personal riding habits, weather, vehicle condition, and ot
2013 Motorcycle Model Guides
2012 Motorcycle Model Guides
2013 ATV/Quad Model Guides
Unread postPosted: Fri Jun 22, 2012 4:57 pm
Real Name: a big secret
My Motorcycle: 1987 Kawasaki Concours
I want one so much, I would cheerfully kill and torture anyone you like if you gave me one.....LOL.....well not really, kill and torture that is....but I do want one, the only bike I want more is the Sprint ST, which I think is a tad bit more sporty then the GT....still...an awesome vote from me natch. :uk: :ohyea: :uk:
Unread postPosted: Fri Jun 22, 2012 5:20 pm
Years Riding: 20
I don't think it really came across how much you like the bike... :laughing:
Ok, in all seriousness, what is it that really turns your crank about the 2012 Triumph Sprint GT? Power? Handling? Style or maybe the alternator output or color of the front tire? :D
:taco: <-- that smilie always makes me hungry, might have to get tacos tonight. :pizza:
Unread postPosted: Fri Jun 22, 2012 7:54 pm
Best I could do was cool, I didn't like the looks of the side bags and I just can't get my brain to make my body like the sport riding stance.
The side bag looks like it was originally made too big and someone cut off the back end to make it fit the bike, there may be a lot of room in there but I think the bike suffers from the look.
As to the colour of the front tire, meh, I like the rear tire colour better...
Other than that, a cool bike
Unread postPosted: Fri Jun 22, 2012 10:24 pm
Real Name: Dino
Years Riding: 5
My Motorcycle: BMW R1150R Edition 80
Look at the other bikes in the class: VFR1200, R1200RT, Concours 14, FJR. Compared to them, the Sprint is gorgeous, even if it's one of the older sport-touring models around. Plus, it's a Triumph triple? How can it not be cool?
Unread postPosted: Sat Jun 23, 2012 1:09 am
It's a nice bike and attempts to fix the issues with the Sprint ST to make it a better two-up tourer. It's longer and the passenger seat is lower due to the loss of the underseat exhausts. With this change it lost a lot of its good looks in my opinion and apparently it doesn't handle as well either. Therefore it's a cool from me whereas the ST would have been awesome.
HighSides Trips and Pics
Unread postPosted: Sat Jun 23, 2012 3:57 am
In many ways, I have to agree with High Side's points not all the changes from the ST to the GT are positive in regards to looks and sporty performance.
When Triumph first released the Sprint, it already had a the Trophy filling the big ST niche. It was a good pairing in my opinion, the Trophy lean more towards the gentleman touring side of the ST world whereas the Sprint leaned more towards the sporty hooligan side. When the Trophy was discontinued, the Sprint ST slowly edged up more towards the touring side and in my opinion sort of stopped at the halfway point between hooligan and gentleman, a great all rounder bike and if given a choice between owning a brand new 2012 GT or a 2011 ST, I would go with the ST.
I do have one worry about the GT and that Triumph is about to make the same mistake as Honda and Kawasaki have made, forgetting what ST's are all about, having a bike that is joy and comfortable enough to ride all day and still have the heart of a hooligan when it comes time to blast through the twisties. I currently ride a Concours 1000, a great bike, fast and fairly nimble but when I sat on the Connie 14, it felt huge and lumbering, the same with the Honda ST aka the Pan European.
Triumph, in changing the Sprint's designation from ST (Sport Touring) to GT (Grand Touring) hints at this push to a bigger and less sporty bike, I fear they are loosing their focus on sporty bikes for which they are known for. In my opinion, bigger is not always better and the more bells and whistles you put on a bike, the less fun it can be. If Triumph continues in this direction, they may soon have to come up with another lighter ST model, perhaps an ST version of the Daytona.
Still, the Sprint GT is in my opinion awesome, it is one of the few ST's apart for the FJ1200 that tried to stay within the sporty side of the ST equation. Oh and Doc, that luggage comes off and the Sprint is one of the few ST bikes that actually look good without its baggage. Even my Connie 1000 looks a little odd without its panniers on.
Unread postPosted: Sat Jun 23, 2012 8:58 am
Well today there has been a new Trophy 1215 announced so the GT will have a thinner slice of the sport-touring market. As for the old ST, last fall I damned near bought one at a screaming price - tornado red with factory bags. After getting to ride it for an hour or so, the bike hit all the right nerves. If I would have bought it I would have never had a chance to go for the new VFR however. The jury is still out on whether or not that was a good move....
Damned good looking bike:
Unread postPosted: Sat Jun 23, 2012 9:04 am
How about an ST using the 800cc Tiger engine? Would be about perfect in my opinion.
Unread postPosted: Sat Jun 23, 2012 9:29 am
Years Riding: 20
Yes indeed. I had that information as of June 20th but it was embargoed till end of 22nd. but here you go (more to follow monday with it's own page and specs in our 2013 Motorcycle Guide)
http://www.totalmotorcycle.com/BBS/viewtopic.php?f=12&t=45317
However, back to the discussion of the 2012 Triumph Sprint GT...
Users browsing this forum: snakedoctEr726 and 169 guests
cron
