2012 Yamaha Raider SCLMore photos and information:
http://www.totalmotorcycle.com/motorcycles/2012models/2012-Yamaha-RaiderSCL.htm
2012 Yamaha Raider SCLVery limited edition Custom Raider S for ultimate culmination of style, power and performance..
A true productin custom unlike no other. Introducing the all-new 2012 Yamaha Raider SCL - a very special, very limited production Raider for those wanting a truly unique chopper-inspired machine. Only 500 will be built and will feature everything that makes the 2012 Yamaha Raider S one of the world's great performance cruisers and more.
2012 Yamaha Raider SCL Highlights and Key Features:
Key Features:
•The limited production Raider SCL is loaded with premium cruiser features. Crafted for riders who value exclusivity, only 500 of these exceptional machines will be built.
•Newly developed high-metallic Blazing Orange paint was created specifically for the Raider SCL. Coupled with a metal flake and shine made possible by a 6-layer painting process, its vibrancy is unlike any other color produced for a Star® Motorcycle. This bike is sure to stand out from the crowd.
•Stainless steel mesh throttle cables as well as clutch and brake lines give this bike a premium look.
•Custom 5-spoke chrome wheels co-developed by Star and Performance Machine, with matching chrome pulley and chrome belt guard, help elevate the Raider SCL to a true production custom.
•Great attention to detail was taken into consideration when designing the genuine leather two-tone seat with embossed SCL logo, and matching orange stitching – keeping the discerning cruiser customer in mind. Over time, the seat will develop a character of its own and will be unlike any other.
•An exclusive metal SCL badge with hologram is placed on top of the fuel tank as a constant reminder to its owner that only 500 of these unique machines exist.
New for 2012:
•The 2012 Raider SCL is a new model for 2012.
2012 Yamaha Raider SCL Features and Benefits
ENGINE
•113-cubic-inch (1854cc) air-cooled, OHV with 4 valves per cylinder, pushrod 48-degree V-twin pumps out max torque at just 2500 rpm and max power at 4500 rpm for powerful, relaxed cruising.
•Four pushrod-activated valves and two spark plugs per cylinder provide optimum combustion efficiency along with classically beautiful engine architecture.
•Ceramic-composite plated cylinders for superior heat dissipation with forged pistons cooled by oil jets. Provides outstanding reliability and longer engine life.
•9.48:1 compression ratio and aggressive cam timing increase power output across the board.
•Computer-controlled, twin-bore fuel injection monitors multiple engine parameters to calculate perfect mixture under all conditions; wide-angle 12-hole fuel injectors provide excellent atomization.
•A 3.5-liter airbox is hidden in the area below the fuel tank for great performance and clean styling.
•Two-into-one-into-two exhaust with Exhaust Ultimate Power valve (EXUP®) inside boosts torque in the 2500~3500-rpm range.
•Special custom-machining of the cooling fin edges gives a jewel-like appearance to the engine as light hits it from different angles.
DETAILS / FEATURES
•Left-thumb operated high-beam switch, and right-thumb activated accessory driving light switch for great visibility.
•Jewel-like fit and finish, and Star quality paint, chrome and attention to detail are evident all over the Raider.
•Cool, tank-mounted instrumentation complements the custom look, and contains analog speedometer and fuel gauge, along with twin digital tripmeters, odometer and self-diagnostics.
•Bright multireflector headlight, LED taillight, and amber turn signals behind clear lenses give a custom look.
•02 sensor and three-way catalyst reduce emissions.
•Raider SCL (Star Custom Line) comes equipped with billet wheels & pulley, custom leather seat, braided stainless steel throttle cables, clutch and brake hoses.
2012 Yamaha Raider SCL - USA Specifications/Technical Details
MSRP* $19,990 (Blazing Orange) Available from February 2012ENGINE
Type 113-cubic-inch (1854cc) air-cooled V-twin OHV, 4 valves/cylinder
Bore x Stroke 100.0 x 118.0mm
Compression Ratio 9.48:1
Fuel Delivery Twin-Bore electronic fuel injection; throttle position sensor
Ignition TCI: Transistor Controlled Ignition
Transmission 5-speed, multiplate wet clutch
Final Drive Belt
CHASSIS
Frame Double cradle
Suspension / Front Telescopic fork; 5.1-in travel
Suspension / Rear Swingarm; 3.5-in travel
Brakes / Front Dual hydraulic disc, 298mm
Brakes / Rear Hydraulic disc, 310mm
Tires / Front 120/70-21
Tires / Rear 210/40-18
Wheels 5-spoke cast
DIMENSIONS
Length 101.2 in
Width 36.4 in
Height 45.9 in
Seat Height 27.4 in
Ground Clearance 5.8 in
Wheelbase 70.9 in
Fuel Capacity 4.2 gal
Fuel Economy** 42 mpg
Wet Weight*** 729.9 lb
OTHER
Warranty 1 Year (Limited Factory Warranty)
2013 Motorcycle Model Guides2012 Motorcycle Model Guides2013 ATV/Quad Model Guides
