2009 Honda DN-01 - COOL WALL VOTE: FAIL
Your Coolness Factor of the 2009 Honda DN-01 is...
View results
Unread post by totalmotorcycle » Fri Mar 18, 2011 5:42 am
2009 Honda DN-01
http://www.totalmotorcycle.com/photos/2 ... a-DN01.htm
2009 Honda DN-01
Honda's stunning new DN-01 is in a class of its own—the world's first crossover bike. Styled like a sportbike, but offering Honda's radical new HFT Transmission, it's an automatic unlike anything you've ever seen. You can shift it into six preset ratios, or you can let it function as a stepless, no-shifting Constantly Variable Transmission, or CVT. The DN-01 is a perfect choice if you're looking to get into motorcycling or if you're just a long-time rider who wants to be on the most cutting-edge bike out there.
It's like no motorcycle you've ever seen. And it's definitely like no motorcycle you've ever ridden. The revolutionary Honda DN-01 is designed to create a nearly seamless connection between you and your riding environment, with a relaxed, low seating position and a clear view to the road ahead. Its Human Friendly Transmission (HFT) allows you to ride in fully automatic mode, or you can shift it like a manual transmission via handy handlebar-mounted push buttons. You can even rev the powerful V-twin engine at stoplights, something most automatic transmissions won't allow.
Honda's reputation for forging new categories in motorcycling takes its latest form in the radical DN-01. This futuristic machine combines true sporting performance with a fully-automatic transmission, a low seat height and exceptional style.
Features & Benefits
- Colors include Candy Dark Red and Black.
Unique Features
- Powerful 4-valve, 680cc liquid-cooled V-twin engine.
- HFT transmission is a continuously variable, hydromechanical design that automatically and seamlessly changes drive ratios to produce strong, smooth acceleration. Unlike conventional belt-drive designs, HFT is compact, quiet, no scheduled maintenance, and features two automatic modes and a six-speed manual mode with push-button shifting.
- Low 27.2-inch seat height assures flat-footed confidence when stopped.
- Large-diameter 41mm front fork and single-shock Pro Arm® Rear Suspension (see Technology Section) provide a sporting ride on low-profile Z-rated radial tires.
- Combined ABS (LBS-ABS, see Technology Section) triple-disc brake system for sure-footed braking in varying conditions.
- Combined Braking System (CBS) provides excellent braking power for added confidence in a wide range of operating conditions. CBS applies front braking force whenever the rear brake is operated.
- On the DN-01, equipped with dual front disc brakes with three-piston calipers and a twin-piston rear caliper, rider application of the front-brake lever activates all six brake pistons in the front calipers. Application of the rear-brake pedal activates the dual pistons of the rear caliper and the center piston of the front-left caliper.
- Anti-Lock Braking System (ABS w/CBS) utilizes modulators- one each on the front and rear wheels- driven directly by specially developed electric motors. In operation, an Electronic Control Unit (ECU) monitors wheel and vehicle speed. If one of both of the wheels approach a locking condition, the modulators, via a signal from the ECU, lower hydraulic pressure by acting directly on the brake piston(s). As wheel speed re-approaches motorcycle speed, the hydraulic pressure is increased. This entire process is repeated numerous times in just one second, resulting in optimal braking pressure and enhanced rider control.
- Beautiful aerodynamic design provides protection from the elements.
2009 Honda DN-01 - Specifications
MSRP: $14,599 USD
ENGINE
Engine Type 680cc liquid-cooled 52° V-Twin
Bore and Stroke 81mm x 66mm
Induction PGM-FI with automatic enrichment circuit, 40mm throttle bodies and 12-hole injectors
Ignition Digital transistorized with electronic advance
Compression Ratio 10.0:1
Valve Train SOHC; four valves per cylinder
DRIVE TRAIN
Transmission HFT continuously variable, hydromechanical two-mode automatic with six-speed manual mode.
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension 41mm telescopic fork with 4.2 inches travel
Rear Suspension Pro Arm single-side swingarm with single shock, seven-position spring preload adjustability; 4.7 inches travel
Front Brake Combined ABS with dual full-floating 296mm discs and three-piston calipers
Rear Brake Combined ABS with single 276mm disc and three-piston caliper
Front Tire 130/70 ZR17 radial
Rear Tire 190/50 ZR17 radial
DIMENSIONS
Rake (Caster Angle): 28.5°
Trail 114mm (4.5 inches)
Wheelbase 63.2 inches
Seat Height 27.2 inches
Curb Weight 595 lbs (Includes all standard equipment, required fluids and a full tank of fuel—ready to ride)
Fuel Capacity 4.0 gallons, including .08-gallon reserve
OTHER
Emissions Meets current California Air Resources Board (CARB) and EPA standards
Available Colors Candy Dark Red, Black
Model ID NSA700A
Note HFT Automatic Transmission
FACTORY WARRANTY INFORMATION
One Year Unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
2017 Motorcycle Model Guides
2016 Motorcycle Model Guides
Re: 2009 Honda DN-01 - COOL WALL VOTE: In progress
Unread post by totalmotorcycle » Fri Mar 18, 2011 6:27 am
I really wanted to pick a bike that will stir up the discussion and I think the Honda DN-01 is just the bike for that... in fact, is it really even a bike or is it a scooter? Is it our first FAIL vote bike or not?
Ah, the debate!
jstark47
Unread post by jstark47 » Fri Mar 18, 2011 8:17 am
totalmotorcycle wrote:Is it our first FAIL vote bike or not?
Anemic engine, overweight, no luggage or ability to carry anything, and they priced it at $15K (US). I've heard of dealers who've cut the price to half of that, and they still can't sell these things. What market was this bike aimed at? Noobs and seniors? The porky thing weighs 600lbs dry, ferpetesake!!!! Noobs and seniors need a light bike, not this porker. At least the Dullville (which shares the same engine) is 30lbs lighter and $5K cheaper. AND has useful carrying ability.
If you want a sporty ride with automatic, get a TMax. If you want to tour with automatic, get a Burgman or Silverwing. If you just want a plain cool looking bike with automatic, get a Mana. This thing is none of the above. FAIL!!!! Fail, fail, FAIL!!!! :rant:
(is that "stirred up" enuf fer ya, Mike???!!) :mrgreen:
LongBeachNY_F4i
Real Name: Michael
Years Riding: 2
My Motorcycle: 2002 Honda CBR 600F4i
Unread post by LongBeachNY_F4i » Fri Mar 18, 2011 8:30 am
I think they went off on a tangent with this model, but I really like the new 250cc Honda made for this year. Looks like a mini cbr and its great for new riders or smaller framed rider.
Unread post by totalmotorcycle » Fri Mar 18, 2011 8:37 am
Oh, that's really good. :twss:
Unread post by totalmotorcycle » Fri Mar 18, 2011 8:39 am
LongBeachNY_F4i wrote:I think they went off on a tangent with this model, but I really like the new 250cc Honda made for this year. Looks like a mini cbr and its great for new riders or smaller framed rider.
:welcome2: LongBeachNY_F4i to the Total Motorcycle Community... (why not say Hi in the Welcome forum, you'll get a slew of welcomes)
What don't you like about it? Is it the design? The seating? The power? What do you think Honda could have done better?
LongBeachNY_F4i
Real Name: Michael
Years Riding: 2
Unread post by LongBeachNY_F4i » Fri Mar 18, 2011 8:59 am
OKKKK. HI EVERYONE, NEW TO COMMUNITY HERE, and looking forward to communicating with all members about the best rush in the world....RIDINGGGGGGGG.
As far as what I dont like...Wellll...The exhaust is hidious. It looks like metallic piece of 2x4 wood. The controls seem very far back over the fuel tank. It looks too stretched out in length. But what really kills me is the "automatic" transmission. This is a motorcycle, its meant to be shifted. You and the bike are one, you much work synergistic with it; feeling every gear, listening to it. Bikes are organic more than mechanistic. A motorcycle is nothing without its rider, as it takes balance, precognitive thinking, and high concentration to operate; where as, a car can pretty much drive on its own (almost anyone can drive a car).
Those are my 2 cents and hope to be an active member on here from here on out.
MiKe
Unread post by sunshine229 » Fri Mar 18, 2011 2:39 pm
Okay boys 'n girls... so far I'm the only one NOT to vote fail (I voted uncool) so let me explain.
For the long term everyday rider this bike sucks. For us, we don't want automatic, heavy, slow, long, UGLY, etc...
BUT for the older man who is new to riding or hasn't ridden since he was 16 (I know, I'm stereotyping here) I can actually see a reasonable market for it.
And hey, it's a Honda so it will last forever! Isn't that enough to not choose fail? :laughing:
Battle is on...
:pirate:
jstark47
Unread post by jstark47 » Fri Mar 18, 2011 3:51 pm
sunshine229 wrote:BUT for the older man who is new to riding or hasn't ridden since he was 16 (I know, I'm stereotyping here) I can actually see a reasonable market for it.
List price is $15,599. Brand new examples are being unloaded on Cycletrader for as low as $7,999. I think that speaks to what kind of market there is for it..... :laughing:
Years Riding: 41
Unread post by High_Side » Fri Mar 18, 2011 4:48 pm
I voted fail as I think most will. I'm all for trying something new but what an abomination.
CentralOzzy
Real Name: AL
Years Riding: 42
Unread post by CentralOzzy » Fri Mar 18, 2011 5:32 pm
I have seen one in the flesh....The fairing looks top heavy & weird. The rear end kinda looks ok.
Kingshead
Real Name: Martin
Years Riding: 100
My Motorcycle: 1999 Honda Shadow VT1100C2 A.C.E.
Unread post by Kingshead » Sat Mar 19, 2011 12:53 pm
For a sport bike (I know, I know, it's not really a sport bike) it looks better than most modern iterations. NOW if we were to look at Cafe's of old, then we would be talking. I guess you can tell I'm kind of a "vintage look" guy myself.
Martin
Welcome to the Horde!!!
Markg1
Real Name: Mark
Unread post by Markg1 » Sun Mar 20, 2011 1:21 am
I know of a person that use to ride but can't any more because of a serious accident. This person can now walk with a help of a brace on his left leg but is unable ride because he cant shift the gears. He's thinking about getting this bike because of the transmission. If this bike puts him back in the saddle, then I vote awesome! Besides, it has two wheels...
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Mon Mar 21, 2011 4:33 am
I usually find something to like about pretty much anything on two wheels, but this is just pointless. They should've just had an automatic tranny option for the Dullsville; at least it would be practical and useful. Like duct tape. And just as sexy.
Unread post by totalmotorcycle » Mon Mar 21, 2011 5:52 am
CentralOzzy wrote:I have seen one in the flesh....The fairing looks top heavy & weird. The rear end kinda looks ok.
I agree with you completely. I had the opportunity to see one parked on the side of the road here in the UK last year and it looks really odd, you don't know what to make of it. It's lower in total height then you think it would be and looooong. Other than this one I've never seen another outside of a motorcycle show or showroom.
Unread post by totalmotorcycle » Mon Mar 21, 2011 7:04 am
Markg1 wrote:I know of a person that use to ride but can't any more because of a serious accident. This person can now walk with a help of a brace on his left leg but is unable ride because he cant shift the gears. He's thinking about getting this bike because of the transmission. If this bike puts him back in the saddle, then I vote awesome! Besides, it has two wheels...
I think that is a great use for this motorcycle if it works for him. But as this is a very special case for the use of the DN-01 I don't know if it would warrent an awesome vote.
But I'm all with ya it would be awesome for him if he does work out.
Automatic transmissions on motorcycles have been tried since the Honda CB250A and CB400A of the early 80's and a few models here and there in the 2000's (like the FJR1300A) but all with mixed successes.
jstark47
Unread post by jstark47 » Mon Mar 21, 2011 9:09 pm
Grey Thumper wrote:I usually find something to like about pretty much anything on two wheels, but this is just pointless. They should've just had an automatic tranny option for the Dullsville; at least it would be practical and useful. Like duct tape. And just as sexy.
I agree, an auto trans Deauville would have had some point to it.
This transmission is actually pretty slick, it's quite an engineering accomplishment. And I don't so much object to the idea of auto trans bikes being on the market, so long as I have plenty of choice not to buy them (unlike cars nowadays.. :evil: ) It's just....... WTF was Honda thinking? $15K for a bike too heavy and too impractical for the only conceivable market it could have had. It's as if Honda wanted the thing to fail... :dontgetit:
Unread post by Johnj » Tue Mar 22, 2011 3:59 am
I voted uncool.
that means it so cool I don't get it
JVRR
Real Name: James / Vladimir
Re: 2009 Honda DN-01 - COOL WALL VOTE: FAIL 55%
Unread post by JVRR » Sun Mar 27, 2011 3:03 am
First thought: How do you sit on it?
Second thought: It looks sort of like a Street Shark.
-JV
Xbox LIVE!: "Vlad is Rad"
PSN: "Vlad_is_Rad"
SCII: "Volodya" (code: 314)
Gummiente
Years Riding: 35
My Motorcycle: '15 HD Road Glide
Unread post by Gummiente » Sun Mar 27, 2011 9:44 am
I'm arriving late to the party, but I vote "uncool", for much the same reasons as the others who have given it a thumbs down - heavy, expensive, butt-ugly, etc. The automatic transmission is about the only interesting part of the bike, but like others I think it would have been put to better use on another model in the Honda lineup.
I didn't vote "fail" because at least it still has two wheels and an engine.
:canada: Mike :gummiente:
'15 Road Glide
"If loud pipes really did save lives, imagine what you
could accomplish if you learned how to ride that thing"
Users browsing this forum: Gummiente, markdcoco, pchast and 163 guests
cron
