1987 Yamaha radian yx600 clutch problem
Papaicon
Real Name: Rob papa
My Motorcycle: 1987 Yamaha radian yx600 bobber
#1 Unread post by Papaicon » Fri Oct 24, 2014 12:16 pm
I have a 1987 radian. It's stars fine in neutral, but when I pull the clutch and put it in gear it jumps and dies. I've adjusted the cable at the top and bottom, but it won't disengage.
Re: 1987 Yamaha radian yx600 clutch problem
#2 Unread post by Johnj » Sat Oct 25, 2014 9:58 am
Either your clutch plates are all stuck together or your clutch basket has problems. It might be the push rod or the clutch basket (the inner or the outer or both). Good luck.
skilzox
Real Name: fagiki
Years Riding: 3
My Motorcycle: 1992 yamaha rs
#3 Unread post by skilzox » Mon Jul 13, 2020 9:00 am
My bicycle begins fine in impartial yet when I pull grip switch and put into first it hops and passes on. Any thoughts why the grasp isn't withdrawing. I have balanced it looser and more tight with no karma. Thank ahead of time.
hannahberry
My Motorcycle: moto
#4 Unread post by hannahberry » Mon Sep 14, 2020 9:01 pm
Everything will get better if you really focus on it. Your information too, I'm sure you focused a lot on getting a full article.
