Total Motorcycle Forums • View topic - 82 Honda CM450 carb overflow
Post new topic Reply to topic  [ 12 posts ]  Go to page 1, 2  Next
Unread postPosted: Fri Jul 15, 2011 10:46 pm
Real Name: sean
Years Riding: 1
My Motorcycle: honda cm450
Hello,
I have an 82 Honda CM450 and it is leaking about 1 drop of gas every second out of the left float bowl overflow. I have taken the bowl off and everything looks good. The floats are clean move fine and are in good shape.
Anyone have any ideas on what the issue can be?
Thanks,
Sean
Unread postPosted: Fri Jul 15, 2011 11:58 pm
Hello and welcome to the forum. The left carb's float is set wrong. Or the float needle seat is dirty. It's not shutting down the fuel soon enough. So it's leaking.
Unread postPosted: Sat Jul 16, 2011 12:12 am
Real Name: sean
Years Riding: 1
Thanks, I will try and adjust them tomorrow.
Unread postPosted: Sat Jul 16, 2011 12:18 am
I don't think it's off by much. Good luck.
Unread postPosted: Sat Jul 16, 2011 5:58 pm
Real Name: sean
Years Riding: 1
So I swapped the floats and float valve from the right to the left, the right side is still fine and the left still leaks. I will try shooting some compressed air up there and hopefully that will do the trick.
Unread postPosted: Sat Jul 16, 2011 11:28 pm
Up where? and is it a CM 450 A, B, or C?
Unread postPosted: Sun Jul 17, 2011 10:29 pm
Real Name: sean
Years Riding: 1
It is a C i think. I am going to try and shoot some air up into the float needle seat then clean it out. I'm hoping it may do something.
Unread postPosted: Sun Jul 17, 2011 10:57 pm
Do you have a manual for your bike?
Unread postPosted: Sun Jul 17, 2011 11:53 pm
Real Name: sean
Years Riding: 1
Yes just looked it up and it is a C model
Unread postPosted: Mon Jul 18, 2011 9:25 am
Ok set your float level like it says in the book.
Users browsing this forum: pchast, storysunfolding and 50 guests
