Total Motorcycle Forums • View topic - Yamaha XJ600N - Clicking - Timing chain adjustment?
Unread postPosted: Tue Mar 30, 2010 3:36 am
Real Name: Andy
My Motorcycle: 1998/Yamaha/XJ600N
Have noticed an unusual clicking noise coming from near the top of the engine on T reg Yamaha XJ600N. A mechanic I asked thought it could be that the timing chain needs to be tweaked. Is there a way to do this without taking much apart? Any ideas what it could be if not the timing chain. Thanks
Unread postPosted: Tue Mar 30, 2010 8:15 am
Could be valves, or could be your cam chain tensioner. If it's your tensioner it's a pretty easy fix without taking too much off and out. Just pull off the tensioner, check it's spring to see if it's still a very strong push, and if it is then you get to take off the top end to check the chain.
Users browsing this forum: Fwoodard64, thomas Quinn and 65 guests
