Total Motorcycle Forums • View topic - 2001 Yamaha v-star clasic 650
Post new topic Reply to topic  [ 15 posts ]  Go to page 1, 2  Next
Unread postPosted: Wed May 07, 2008 10:57 am
I am currently trying to put this bike back on the road. I have cleaned the carbs and the bike starts and idels.The problem is that when I open the throttle the bike revs up and then starts to surge, meaning that the RPMs go low then High and so on.
Any Ideas where to look for the problem. I have synched the carbs and that did not help.
Do I still have a carb issue or is it else where?
Thank you for any help
Unread postPosted: Wed May 07, 2008 11:01 am
Does sound like a carb issue. You may need to clean em out.
I'd put some Seafoam in the fuel and try to run that through before taking the carbs off though.
Some new spark plugs or a good examination of the wiring might be in order too.
Flickr.
Unread postPosted: Wed May 07, 2008 11:10 am
Jonnythan,
Thanks for the reply.
I ran sea foam through them already and installed new spark plugs and still have the same problem.
Should I take them apart and re-clean them again? The last time I checked all passages and they were clear.
Thanks again for your help
Unread postPosted: Wed May 07, 2008 11:12 am
fshcur wrote:
Jonnythan,
I'm no expert or anything, but I'd probably take em off and go through them again really well.
Might be something else completely though. Others on the board here will probably chime in with better suggestions.
Flickr.
Unread postPosted: Wed May 07, 2008 11:26 am
Souns good Thank you for you help.
This site is great.
Thanks to you all in advance for you help.
Unread postPosted: Wed May 07, 2008 1:28 pm
could be some "crumb" that was stuck in the fuel lines came loose after you started the bike, clogged up the carbs again. Also, depending how thourogh you were with the cleaning, you may want to consider bringing the carbs into a small engine place and getting them dipped.
2006 Kawasaki Vulcan 500 LTD
CMC 049
Unread postPosted: Wed May 07, 2008 6:10 pm
Northerpete,
Thanks for the help.
I will pull the carbs off tomarrow and have them diped this weekend.
I just realized that I never changed the fuel filter. I will change this and flush the fuel pump while the carbs a cleaning.
I will post once this is all completed.
Thank for your help
Unread postPosted: Wed May 07, 2008 11:46 pm
Years Riding: 38
Definitely check the carbs for blockages or restrictions again. It could also be an air leak in the intact tract someplace causing the surge.
Unread postPosted: Fri May 09, 2008 8:42 am
Well I took the carbs completely apart and cleaned them, again only this time I had them "dipped".
I found that the front carb air/fuel screw was set at 1.25 turns out and the rear carb was set at 2.5 turns out.
Can anyone tell me were they should be to start?
The manual says 2.5 turns for each. I am concerned becouse they are not even near being the same. I know they were never played with because I drilled out the plugs myself. I read somewhere that you should start at 1.5 turns out. Just looking for a good starting point.
Thank s for your help
Fshcur
Unread postPosted: Fri May 09, 2008 8:04 pm
People,
Any help here?
anyone anyone at all??
Users browsing this forum: AFVet and 61 guests
