Total Motorcycle Forums • View topic - Popping (and I dont mean popcorn)
Unread postPosted: Wed Mar 16, 2005 12:01 am
Real Name: Dan
My Motorcycle: 2005 Yamaha V-Star 650
What would cause a 78 Honda CB750K to pop a lot? It is a lot like small backfires.
Air filter is fine, fuel is fresh (if that makes a difference), plugs are good and I get a pretty blue spark when I take the plugs out.
Timing?
Fuel / Air mixtures??
2005 Yamaha V-Star 650 Classic
Ural Patrol <Wish list>
Evil will always triumph over good because good is dumb.
Dark Helmet, Space Balls
http://www.patriotguard.org
:USA:
Unread postPosted: Wed Mar 16, 2005 12:13 am
Years Riding: 38
Does this happen when closing the throttle? Under hard accelleration? All the time?
Could be 'decelleration popping' as they jetted bikes pretty lean back then. It is common. Honda XL's and XR's came with a wire mesh screen in the airfilter to keep sparks from this lighting the airfilter on fire. If it only happens with closed or partly closed throttle, it is no big deal.
 Post subject: Popping
Unread postPosted: Wed Mar 16, 2005 9:21 am
Had that problem on a 93 Honda VLX and a 99 Vulcan 1500A - friend had that problem on a 04 Honda 1300VTX. All caused by the same thing - air getting into the exhaust system. Usually around the exhaust port.
Just a thought.
Unread postPosted: Wed Mar 16, 2005 5:33 pm
as Tommcatt said look for air leaks around the exhaust system.
if the pipes are rotted at all it will cause the back firing. not to mention idling problems and fowling of the plugs. if there is any rot at all replace the pipes it's a lot less of a hassle then trying to weld because if it is rotted out side then the insides are going to be even worse. eBay has good deals on 4 into 1 sets right now buy now as low as $115.00. Good luck and get out ridding.
Unread postPosted: Fri Mar 18, 2005 9:26 pm
Real Name: Dan
It only happens at idle and decelleration, never during excelleration. The pipes are pretty old looking and plenty rusted but they dont appear to have any integrity issues.
One more question. The beast refuses to idle if it is not warmed up. Could the two issues be related?
:USA:
Unread postPosted: Sun Mar 20, 2005 4:02 pm
Years Riding: 38
At a guess, I would say it is the stock (lean) jetting causing this. It won't hurt anything but it can be sorted out with a jetting session if you so desire. MAny bikes from that era have a similar problem with cold idle and de-cell popping.
Unread postPosted: Sun Mar 20, 2005 6:58 pm
Sounds like an air fule mixture problem to me. :twocents:
Users browsing this forum: No registered users and 53 guests
