Total Motorcycle Forums • View topic - Parts That Break the Most
Unread postPosted: Sat Feb 14, 2009 5:38 pm
Just trying to get some general info, what would you experts says breaks down the most, generally, on motorcycles? :roll:
Unread postPosted: Sat Feb 14, 2009 7:46 pm
Are you talking the bike in general? Or a specific area?
In general I'd say carbs are the most troublesome part. Followed by the chain/sprocket most bikes have. Then I'd have to say the clutch after that.
And I know chain/sprockets are designed to wear out, but most are misadjusted and so wear out/break more often than they should.
Unread postPosted: Sun Feb 15, 2009 6:31 am
Years Riding: 38
Good sense and speed limits, in that order.....
.... and pretty much much what wrider said, too...
..... oh yeah, and tires.... you can chew through those in a hurry... not really 'breaking' either.... but still a rather involved mechanical operation to change...
 Post subject: Wrider
Unread postPosted: Mon Feb 16, 2009 8:05 am
You have a good question. General or specific. I was kinda going after, I don't know if I can do this, the 80/20 rule. What 20% of the parts, generally cause 80% of the problems in terms of breakdown. I.E, do certain electrical parts break a lot, is it lights, or fuses, or chains or sprockets like you say.
I'm looking at inventorying some parts and wanted to look at some things generally to stock.
Thanks for your help
Unread postPosted: Mon Feb 16, 2009 3:52 pm
Depends on the bike. Most modern bikes are very reliable if they have not been abused. I can't think of anything off hand that would be necessary to have a stock of.
'07 Suzuki V-Strom DL650
Molon Labe!!!
Unread postPosted: Mon Feb 16, 2009 10:37 pm
This runs the gamut. In my opinion, as other posters have said, a properly maintained and cared for modern motorcycle is quite reliable.
From my experience, I tend to have more electrical problems than anything else. And I've owned a mix of Japanese and Italian bikes. I've had 4 voltage regulators go out. 3 on a Suzuki and 1 on a Ducati. I've had a fuel filter rupture (odd ball low probability event... but it happened).
Knock on wood but in 14 years and a 100K of commuting and traveling by bike, I haven't been stranded due to a mechanical. Not even so much as a flat tire.
Two Big Jugs or Four Small Cups. Life's Good.
`08 CBR1000RR "Ayane" - the Shinkansen
`07 S4Rs "Persephone" - urban Monster
`00 SV650 "Ayame" - trackday special
Unread postPosted: Tue Feb 17, 2009 10:06 pm
As far as things to stock I'd say an extra chain and sprocket. Followed by brake fluid/oil. Then that's about it. Maybe if you're really paranoid some extra carb needles/jets and clutch plates, but I wouldn't worry about those.
Users browsing this forum: 1ironman, Wrider and 28 guests
