#SUZUKI ANNOUNCES NEW #2015 #RM-Z450
Team Suzuki Press Office – May 16.
Suzuki Motor Corporation has today announced the launch of its most radically-changed production motocross machine in recent years; the new 2015 RM-Z450 that is directly derived from the Factory bikes currently being raced by Clement Desalle, Kevin Strijbos and James Stewart in the World MXGP, AMA Supercross and AMA Motocross Championships.
After several years of regular refinements and improvements since its introduction in 2005 – plus a major redesign in 2008 - the 2015 RM-Z450 features a multitude of cutting-edge innovations tried-and-tested by Rockstar Energy and Yoshimura Suzuki Factory Racing riders in world championship competition.
The most-eagerly-anticipated feature for 2015 is the revolutionary ‘Suzuki Holeshot Assist Control’ system (S-HAC), plus the new Showa SFF-AIR front forks, although the machine features a multitude of further improvements and changes.
Suzuki Holeshot Assist Control:
The ‘Suzuki Holeshot Assist Control’ system features two different modes to aid a rider to get-out-of-the-gate faster and more-efficiently than ever: For hard surface or slippery conditions at the starting gate, choose A-Mode. In this setting, Holeshot Assist Control alters ignition timing to reduce wheel slip and to deliver smooth acceleration to take you into the lead. Then after 1.2 seconds (or when you reach third gear), the system returns to normal ignition timing. When conditions at the starting gate provide better traction, and a more aggressive launch is needed, choose B-Mode. For these conditions, Holeshot Assist Control advances ignition timing to allow increased throttle response and stronger acceleration off the line. One of three conditions will then return the ignition to normal operation: after 4.5 seconds has passed since launch - when you shift to fourth gear - or when the throttle is closed (whichever happens first). You can turn the Holeshot Assist Control system Off when no holeshot assistance is desired.
Showa SFF-AIR Front forks:
Also brand-new for 2015 are the state-of-the-art Showa SFF-AIR (Separate Function front Fork-AIR) which are an advancement on last year’s SFF forks, which featured a coil spring in one side and an oil-damper in the other fork-leg. The latest forks do-away with any need to buy different-rate springs and then having to make further adjustments to suit the riders’ weight or skill-level. Now, the forks are tuned and dialled-in via a pump and the heaviest part – the coil spring – eliminated saving 1.100g weight.
The weight saving has also allowed Showa to increase the tube diameter (now 49mm from 48mm in 2014) and also increase the piston (39mm from 38mm) and rod size (14mm from 12.5) for greater suspension performance. Adjustment and tuning is now carried-out via three separate air valves – an inner and outer air pressure valve on the top of the fork and a balanced air pressure valve on the lower fork.
Other New 2015 Features:
Since its launch nine years ago - and as the first motocross machine to feature electronic fuel-injection - the RM-Z450 has won the World MX1 Motocross Championship (Steve Ramon in 2007), six AMA Supercross and Motocross titles (Ricky Carmichael, Chad Reed and Ryan Dungey) plus 10 further national titles in total from Australia (Daryl Hurley, Matt Moss and Chad Reed), Germany (Ken Roczen and Marcus Schiffer), New Zealand (Daryl Hurley) and Japan (Yoshitaka Atsuta).
Each year, Suzuki has worked closely with its Factory teams to make improvements to its production bikes following extensive testing; and for 2015, the RM-Z450 gets many new modifications that have also led to an overall curb-weight reduction of 1kg.
• Redesigned Frame: Internal frame parts are reshaped to optimise rigidity and weight reduced by 4% without sacrificing rigidity.
• Improved Engine Starting: A longer, re-shaped kickstarter lever, redesigned de-compression system, revised kick-drive gear ratio, relocated kick idle gear and the addition of a breather gear to improve engine starting.
• Improved Cooling: The water hose routing is now revised, along with a redesigned water pump cover for more-efficient cooling.
• Smoother Gear-Shifting: Gear-matching precision is increased, along with a revised gear-shift cam for more-precise and smoother operation.
• US Models: Now feature an extra internal muffler pipe to comply with AMA regulations.
SUZUKI ANNOUNCES NEW 2015 RM-Z450
- Years Riding: 32
2023 Motorcycle Model Guides
