Factory custom cruiser strykes- All new addtion to Star rang
Years Riding: 32
Factory custom #cruiser #strykes- All new addtion to #Star range revealed
The handsome new Yamaha XVS1300 Stryker is a new breed of cruiser that combines a classic raked-out chopper style chassis with a gutsy liquid-cooled V-twin engine to create something very special.
Attention to detail on the Stryker is outstanding, with features such as steel fenders, 21-inch front wheel and cooling fins accentuating its timeless good looks and reinforcing its authentic appeal.
High-torque V-twin engine
At the heart of this beautifully crafted new cruiser there's a 1304cc liquid-cooled 60-degree SOHC V-twin engine that blends classic cruiser looks with modern technology. Big V-twins are all about torque, and the Stryker excels in this area. With 4 valves per cylinder combined with a 9.5:1 compression ratio and performance-oriented camshaft designs, this 1304cc engine pushes out a pulsating wave of torque for thrilling acceleration and easy cruising.
Behind its black and silver exterior this high-torque engine is packed with high-tech design features that optimise its performance and strength. The massive 100mm diameter pistons run in ceramic composite cylinder sleeves, and the rocker arms are equipped with roller bearings for reduced frictional losses.
For that charismatic V-twin sound and feel Stryker runs with a single crankpin, while forged con rods ensure high levels of durability. Rider comfort is assured thanks to the fitment of dual counter balancers, and for stable and efficient engine running performance over a wide range of temperatures and altitudes, the 1304cc engine is fed by a sophisticated fuel injection system.
With its large 'air-cooling design' fins, unobtrusive radiator and lack of visible external coolant pipes, this mighty liquid-cooled V-twin engine possesses the classic good looks of a traditional air-cooled design. This has been achieved by running the coolant through hidden hoses and internal engine passages, giving the new Stryker a truly timeless image, combined with the performance advantages associated with liquid cooling.
To optimise overall engine performance this new cruiser is fitted with a striking large-diameter 2-into-2 exhaust system with slash cut tailpipes that emit a gutsy burble.
The smooth shifting 5-speed gearbox transmits the big V-twin engine pulses to the road via an efficient belt drive. As well as being clean and quiet running, the durable belt drive also requires minimal maintenance, making it ideally suited to Stryker.
Engine Technical Highlights
•High torque 1304cc liquid-cooled SOHC 60 degree V-twin
• Fuel injection for stable performance and fuel efficiency
• 4 valves per cylinder (36mm inlet, 32mm exhaust)
• Forged con rids and ceramic composite cylinders for durability
• 'Air-cooling design' fins with hidden liquid cooling system
• 9.5:1 compression ratio
• Slash-cut 2-into-2 exhaust system
• Quiet and efficient belt drive
• Single crankpin and high-performance camshafts
• Dual counterbalancers for smooth running
Raked out front end for classic chopper style
One of the most striking features on the new chassis is the radically raked out front end which gives this new V-twin cruiser a classic 'chopper' image. The use of specially designed triple clamps give a fork rake of 40 degrees for a more aggressive and striking 'long and low' image.
The raked-out front end delivers superb straight-line chassis handling characteristics, yet at the same time Stryker's frame geometry and triple clamp configuration have also been designed to give light and agile handling at lower speeds, for great all round performance in the city and on the highway.
In true custom tradition Stryker is equipped with an ultra low seat that perfectly complements the bike's overall style. At only 670mm high, the stepped dual seat allows the rider to get both feet on the ground when stationary for added comfort and confidence.
The raised pull-back handlebars together with a low seat and forward-mounted footrests give a relaxed riding position that allows the rider to sit back and enjoy the easy handling and big torque pulses from the 1304cc V-twin engine.
Good news for customers who want to modify their bike - Stryker is equipped with steel front and rear fenders. Steel allows owners to cut and modify fenders to suit their own requirements.
To accentuate its bold and muscular image Stryker is equipped with beautifully styled 5-spoke aluminium wheels fitted with low profile tyres. At the rear there's a wide 210/40-18 tyre, while the large diameter front wheel runs on a 120/70-21 tyre, giving excellent traction with easy steering.
The lightweight wheels are fitted with large diameter disc brakes, with a 320mm diameter front disc and a 310mm rear disc giving smooth and effective braking performance.
Chassis Technical Highlights
• Radical 'chopper-style' front end with 40 degrees of fork rake
• Solid straight-line performance with easy low-speed handling
• Ultra-low seat height of 670mm
• Steel front and rear fenders for increased customising potential
• 5-spoke cast aluminium wheels: 21-inch front, 18-inch rear
• Low profile tyres: 120/70-21 front, 210/40-18 rear
• Large discs: 320mm single front, 310mm rear
• Relaxed riding position
• Sculpted fenders and bodywork
Star Stryker specifications
Engine type Liquid-cooled, 4-stroke, 4-valves, V-type 2-cylinder, OHC
Displacement 1304cc
Bore x stroke 100.0 mm x 83.0 mm
Compression ratio 9.5 : 1
Lubrication system Wet sump
Clutch Type Wet, Multiple Disc
Carburettor Fuel Injection
Ignition system TCI
Starter system Electric
Transmission system Constant Mesh, 5-speed
Final transmission Belt
Frame double cradle
Front suspension system Telescopic forks, Ø 41 mm
Front travel 135 mm
Caster Angle 34º
Trail 109 mm
Rear suspension system Swingarm
Rear Travel 100 mm
Front brake Hydraulic Disc, Ø 320 mm
Rear brake Hydraulic single disc, Ø 310 mm
Front tyre 120/70-21M/C 62H (Tubeless)
Rear tyre 210/40R18M/C 73H (Tubeless)
Overall length 2535 mm
Overall width 860 mm
Overall height 1130 mm
Seat height 670 mm
Wheel base 1755 mm
Minimum ground clearance 150 mm
Wet weight (including full oil and fuel tank) 293 kg
Fuel tank capacity 15 litres
Oil tank capacity 3.7 litres
Warranty Five years
Colours Matt Grey, Midnight Black
RRP (inc GST) Midnight Black $14,999
Matt Grey $15,299
2023 Motorcycle Model Guides
Locked
